Read/write mysql database
#60
Use this table structure for data. trend_id will be the same id as in LM.
CREATE TABLE `trends_data` (   `trend_id` int(11) NOT NULL,   `dt` datetime NOT NULL,   `value` double DEFAULT NULL,   PRIMARY KEY (`trend_id`,`dt`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8;
Updated script:
require('trends') require('luasql.mysql') env = luasql.mysql() --DATABASE CONNECTION -> (DB_NAME, USERNAME, PASSWORD, MYSQL_SERVER_IP, MYSQL_SERVER_PORT) dbcon, err = env:connect('CONFIDENTIAL', 'admin', 'CONFIDENTIAL', 'lm-database.CONFIDENTIAL.us-east-1.rds.amazonaws.com', 3306) if dbcon then   items = db:getall('SELECT id, name FROM trends')   trends.NaN = 'NULL'   dates = {     ['start'] = os.date('*t'),     ['end'] = os.date('*t'),   }   dates.start.day = dates.start.day - 1   date = string.format('%04d-%02d-%02d',     dates.start.year, dates.start.month, dates.start.day)   for _, item in ipairs(items) do     id = item.id     data = trends.fetch(item.name, dates)     values = {}     if data and #data > 0 then       step = 1440 / #data -- in minutes       for i, val in ipairs(data) do         mins = (i - 1) * step         datetime = string.format('%s %02d:%02d:00',           date, math.floor(mins / 60), mins % 60)         values[ #values + 1 ] = string.format('(%d,"%s",%s)',           id, datetime, tostring(val))       end     end     if #values > 0 then       query = 'INSERT INTO trends_data (trend_id, dt, value) VALUES ' .. table.concat(values, ',')       dbcon:execute(query)     end   end   dbcon:close() else   log('mysql connection failed ' .. tostring(err)) end    env:close()
Read/write mysql database - by gjniewenhuijse - 14.01.2016, 09:49
RE: Read/write mysql database - by admin - 14.01.2016, 10:03
RE: Read/write mysql database - by RSV4 - 20.03.2016, 10:33
RE: Read/write mysql database - by admin - 21.03.2016, 06:59
RE: Read/write mysql database - by RSV4 - 21.03.2016, 09:59
RE: Read/write mysql database - by admin - 11.10.2016, 10:24
RE: Read/write mysql database - by g2g2g2 - 02.11.2016, 13:40
RE: Read/write mysql database - by g2g2g2 - 08.11.2016, 08:23
RE: Read/write mysql database - by admin - 08.11.2016, 08:26
RE: Read/write mysql database - by RSV4 - 06.12.2016, 23:08
RE: Read/write mysql database - by admin - 07.12.2016, 07:12
RE: Read/write mysql database - by RSV4 - 07.12.2016, 08:45
RE: Read/write mysql database - by admin - 07.12.2016, 09:09
RE: Read/write mysql database - by RSV4 - 07.12.2016, 09:27
RE: Read/write mysql database - by RSV4 - 18.12.2016, 00:05
RE: Read/write mysql database - by RSV4 - 18.12.2016, 07:58
RE: Read/write mysql database - by RSV4 - 18.12.2016, 10:28
RE: Read/write mysql database - by RSV4 - 11.01.2017, 23:19
RE: Read/write mysql database - by admin - 12.01.2017, 09:48
RE: Read/write mysql database - by RSV4 - 12.01.2017, 18:50
RE: Read/write mysql database - by FatMax - 17.02.2017, 12:45
RE: Read/write mysql database - by yeuwoo - 14.03.2017, 03:16
RE: Read/write mysql database - by admin - 14.03.2017, 06:53
RE: Read/write mysql database - by Thomas - 14.03.2017, 14:34
RE: Read/write mysql database - by admin - 05.09.2017, 13:50
RE: Read/write mysql database - by admin - 07.09.2017, 14:47
RE: Read/write mysql database - by pentadom - 18.11.2019, 16:54
RE: Read/write mysql database - by Daniel - 19.11.2019, 08:28
RE: Read/write mysql database - by pentadom - 19.11.2019, 09:37
RE: Read/write mysql database - by admin - 19.11.2019, 09:49
RE: Read/write mysql database - by pentadom - 19.11.2019, 10:22
RE: Read/write mysql database - by admin - 19.11.2019, 12:06
RE: Read/write mysql database - by pentadom - 19.11.2019, 12:23
RE: Read/write mysql database - by admin - 19.11.2019, 14:07
RE: Read/write mysql database - by pentadom - 19.11.2019, 19:12
RE: Read/write mysql database - by admin - 20.11.2019, 07:47
RE: Read/write mysql database - by pentadom - 17.05.2020, 08:18
RE: Read/write mysql database - by pentadom - 17.05.2020, 14:57
RE: Read/write mysql database - by Daniel - 18.05.2020, 07:38
RE: Read/write mysql database - by pentadom - 18.05.2020, 07:55
RE: Read/write mysql database - by admin - 18.05.2020, 07:50
RE: Read/write mysql database - by admin - 18.05.2020, 07:58
RE: Read/write mysql database - by pentadom - 18.05.2020, 08:01
RE: Read/write mysql database - by Daniel - 18.05.2020, 08:06
RE: Read/write mysql database - by pentadom - 18.05.2020, 08:08
RE: Read/write mysql database - by pentadom - 19.05.2020, 16:08
RE: Read/write mysql database - by admin - 20.05.2020, 07:38
RE: Read/write mysql database - by pentadom - 20.05.2020, 16:27
