MqTT in Wiser for KNX
(20.05.2020, 12:40)Daniel. Wrote: First we have to see your script. What fw do you use?
Have you seen this thread?
Hi Daniel thanks for replying.
Wiser has the fw 2.4.0 as you can see in the following image.
I use the script that I publish Admin in this thread
https://forum.logicmachine.net/showthrea...light=mqtt
I have created the resident script at interval 0 and changed the IP address to the address of the pc where the mosquitto broker runs.
The object mapping I have used the same as a test.
if not broker then   broker = '192.168.0.12'   function multiply(mult)     return function(value)       local num = tonumber(value)       if num then         return num * mult       else         return value       end     end   end   -- topic to object map   mqtt_to_object = {     ['in/topic1'] = '32/1/1',     ['in/topic2'] = '32/1/2',   }    -- object to topic map   object_to_mqtt = {     ['1/1/1'] = 'out/topic1',     ['1/1/2'] = 'out/topic2',   }   datatypes = {}   grp.sender = 'mq'   require('socket')   for addr, _ in pairs(object_to_mqtt) do     local obj = grp.find(addr)     if obj then       datatypes[ addr ] = obj.datatype     end   end   mclient = require('mosquitto').new()   mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end   mclient.ON_MESSAGE = function(mid, topic, payload)     local addr = mqtt_to_object[ topic ]     if addr then       local fn = mqtt_to_object_conv[ topic ]       if fn then         payload = fn(payload)       end       grp.write(addr, payload)     end   end   mclient.ON_DISCONNECT = function(...)     log('mqtt disconnect', ...)     mclientfd = nil   end   function mconnect()     local fd     mclient:connect(broker)     fd = mclient:socket()     -- fd ref is valid     if fd then       mclientfd = fd     end   end   mconnect()   function publishvalue(event)     -- message from us or client is not connected     if event.sender == 'mq' or not mclientfd then       return     end     local addr = event.dst     local dpt = datatypes[ addr ]     local topic = object_to_mqtt[ addr ]     -- unknown object     if not dpt or not topic then       return     end     local value = busdatatype.decode(event.datahex, dpt)     if value ~= nil then       if type(value) == 'boolean' then         value = value and 1 or 0       end       mclient:publish(topic, tostring(value))     end   end   lbclient = require('localbus').new(1)   lbclient:sethandler('groupwrite', publishvalue)   lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')   -- run timer every 5 seconds   timer = require('timerfd').new(5)   timerfd = socket.fdmaskset(timer:getfd(), 'r') end -- mqtt connected if mclientfd then   mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')   res, lbclientstat, timerstat, mclientstat =       socket.selectfds(10, lbclientfd, timerfd, mclientfdset) -- mqtt not connected else   res, lbclientstat, timerstat =     socket.selectfds(10, lbclientfd, timerfd) end if mclientstat then   if socket.fdmaskread(mclientstat) then     mclient:loop_read()   end   if socket.fdmaskwrite(mclientstat) then     mclient:loop_write()   end end if lbclientstat then   lbclient:step() end if timerstat then   -- clear armed timer   timer:read()   if mclientfd then     mclient:loop_misc()   else     mconnect()   end end
Putting the log lines suggested in that same post, this is the result.
MQTT 20.05.2020 16:03:19
Resident script:130: bad argument #2 to 'selectfds' (number expected, got nil)
stack traceback:
[C]: in function 'selectfds'
Is it necessary to install a library or package?
The topics are published and the broker subscribed to them.
Thank you.
a greeting
MqTT in Wiser for KNX - by JRP - 20.05.2020, 12:11
RE: MqTT in Wiser for KNX - by Daniel - 20.05.2020, 12:40
RE: MqTT in Wiser for KNX - by JRP - 20.05.2020, 13:55
RE: MqTT in Wiser for KNX - by Daniel - 20.05.2020, 13:59
RE: MqTT in Wiser for KNX - by JRP - 20.05.2020, 18:34
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 07:21
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 10:40
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 10:42
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 11:20
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 11:22
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 11:47
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 11:50
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 15:28
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 10:38
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 11:06
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 12:55
RE: MqTT in Wiser for KNX - by JRP - 19.05.2023, 10:18
RE: MqTT in Wiser for KNX - by admin - 19.05.2023, 10:24
RE: MqTT in Wiser for KNX - by JRP - 19.05.2023, 10:42
RE: MqTT in Wiser for KNX - by JRP - 20.05.2023, 17:10
RE: MqTT in Wiser for KNX - by admin - 22.05.2023, 06:52
RE: MqTT in Wiser for KNX - by JRP - 26.05.2023, 08:21
