Information about database synchronization, storage, script and others
Can you explain what the purpose is of having several schedulers that are synced all the time, why don't you use 1 master scheduler that is located in 1 LM and control the scheduled objects in the other LM's over KNX IP? You can add the Master scheduler in every visu by a frame so when you change it, it change in all the visu's, this way you don't need to sync anything as it is centralized already..
RE: Information about database synchronization, storage, script and others - by Erwin van der Zwart - 09.06.2020, 20:32
