Creat logs in txt file
(02.04.2020, 11:20)admin Wrote: FTP path is /home/ftp, just make sure that you have some algorithm to delete old files. Otherwise you can run out of free space at some point.
I'm still confused on this point. I used Filezilla to connect and placed a doorbell sound file (at what I'm taking from your post above is /home/ftp). My ftp login was user ftp (can choose from ftp or apps). But my Custom Javascript file appears not to see the copied file. For example, in the following file if I uncomment and use the mozilla file, the sound plays fine. But when written as shown here with the local file, the code does not work. Is it a linux permissions thing?
// the following function plays a sound when the doorbell is pressed (Object 0/250/72 is set true) // FTP path is /home/ftp (use Filezilla to put sound file there) $(function(){    grp.listen('0/250/72', function(object) {       if (object.value == true ) { //        var audio = new Audio('https://interactive-examples.mdn.mozilla.net/media/examples/t-rex-roar.mp3');         var audio = new Audio('/home/ftp/Doorbell.mp3');         audio.play();       }    }); });
Can you help me?
Thanks!
Creat logs in txt file - by deimostier - 27.04.2017, 14:03
RE: Creat logs in txt file - by gtsamis - 27.04.2017, 21:55
RE: Creat logs in txt file - by deimostier - 02.05.2017, 14:41
RE: Creat logs in txt file - by gtsamis - 02.05.2017, 14:51
RE: Creat logs in txt file - by mjaanes - 02.04.2020, 10:11
RE: Creat logs in txt file - by admin - 02.04.2020, 11:20
RE: Creat logs in txt file - by tassiebean - 12.06.2020, 15:10
RE: Creat logs in txt file - by Trond Hoyem - 13.08.2020, 09:46
RE: Creat logs in txt file - by Trond Hoyem - 07.01.2021, 12:02
RE: Creat logs in txt file - by admin - 12.06.2020, 15:47
RE: Creat logs in txt file - by tassiebean - 13.06.2020, 03:20
RE: Creat logs in txt file - by admin - 13.08.2020, 11:12
RE: Creat logs in txt file - by admin - 07.01.2021, 12:14
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:03
RE: Creat logs in txt file - by admin - 18.06.2024, 08:14
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:27
RE: Creat logs in txt file - by Daniel - 18.06.2024, 08:33
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:35
RE: Creat logs in txt file - by admin - 18.06.2024, 08:36
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:44
RE: Creat logs in txt file - by Daniel - 18.06.2024, 08:48
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:57
RE: Creat logs in txt file - by Daniel - 18.06.2024, 09:02
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 09:12
RE: Creat logs in txt file - by Daniel - 18.06.2024, 09:12
RE: Creat logs in txt file - by admin - 18.06.2024, 09:15
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 10:00
