Irrigation program
You can create a sequence with any number of outputs this way, just modify the parameters and object list to suit your needs:
mintimer = 5 -- minimum timer value in seconds maxtimer = 60 -- maximum timer value in seconds objects = {   {     output = '1/1/1',     timer = '2/1/1',   },   {     output = '1/1/2',     timer = '2/1/2',   },   {     output = '1/1/3',     timer = '2/1/3',   } } function dosleep(obj)   local timer = grp.getvalue(obj)   timer = tonumber(timer)   if timer then     if timer < mintimer then       timer = mintimer     elseif timer > maxtimer then       timer = maxtimer     end     sleep(timer)   end end for _, item in ipairs(objects) do   grp.write(item.output, true)   dosleep(item.timer)   grp.write(item.output, false) end
Irrigation program - by Domoticatorino - 01.08.2016, 22:34
RE: Irrigation program - by Domoticatorino - 02.08.2016, 19:59
RE: Irrigation program - by admin - 03.08.2016, 06:19
RE: Irrigation program - by Domoticatorino - 18.10.2016, 11:46
RE: Irrigation program - by admin - 18.10.2016, 12:02
RE: Irrigation program - by Domoticatorino - 20.04.2018, 23:21
RE: Irrigation program - by admin - 25.04.2018, 06:21
RE: Irrigation program - by Udelae - 11.03.2019, 17:17
RE: Irrigation program - by admin - 12.03.2019, 07:35
RE: Irrigation program - by Udelae - 12.03.2019, 08:11
RE: Irrigation program - by admin - 12.03.2019, 08:30
RE: Irrigation program - by Udelae - 12.03.2019, 13:18
RE: Irrigation program - by CristianAgata - 30.06.2021, 14:36
RE: Irrigation program - by Udelae - 12.03.2019, 14:36
RE: Irrigation program - by DanielB - 21.03.2019, 11:22
RE: Irrigation program - by Daniel - 30.06.2021, 14:57
RE: Irrigation program - by CristianAgata - 30.06.2021, 16:12
RE: Irrigation program - by balatis - 12.05.2022, 11:47
RE: Irrigation program - by David - 24.10.2023, 08:29
RE: Irrigation program - by Daniel - 24.10.2023, 08:38
RE: Irrigation program - by David - 24.10.2023, 08:47
RE: Irrigation program - by admin - 24.10.2023, 08:50
RE: Irrigation program - by josep - 24.10.2023, 09:17
RE: Irrigation program - by admin - 24.10.2023, 09:18
RE: Irrigation program - by David - 24.10.2023, 09:39
RE: Irrigation program - by admin - 24.10.2023, 09:45
