Curious about the operation of this script
Hello I have this sample script for the definition and call of functions.
function max(numero1, numero2)         if (numero1 > numero2) then            resultado = numero1;            else                                   resultado = numero2;            end                                return resultado;             -- end log('El valor máximo de la comparación de dos valores es',max(4,10)) log('El valor máximo de la comparación de dos valores es',max(6,5))
It works perfectly regardless of the order of the numbers passed to the function, it always returns the largest.
I have this other variation.
max = 4, 10 log('El valor máximo de la comparación de dos valores es', max) function max(numero1, numero2)         if (numero1 > numero2) then            resultado = numero1;            else       resultado = numero2;    end   return(resultado) end
Here the problem is that if I change the order of the numbers, the function does not return the highest, it seems that it always returns the first.
What could this be due to? Is the way to call the function and pass it the arguments wrong?
a greeting
Curious about the operation of this script - by JRP - 07.08.2020, 12:01
