is modbus device online
You can check it like this
-- First parameter is slave ID, second is optional RTU port number (1, 2 or 3; default is 1) function checkrtu(slave, portnr)   local query = 'SELECT active FROM modbus_devices WHERE proto="rtu" AND slave=? AND portnr=?'   if type(portnr) == 'number' and portnr == 2 or portnr == 3 then     portnr = portnr - 1   else     portnr = 0   end   local res = db:getone(query, slave, portnr)   return toboolean(res) end function checktcp(ip, port)   local settings, res   settings = tostring(ip) .. ':' .. tostring(port)   res = db:getone('SELECT active FROM modbus_devices WHERE proto="tcp" AND settings=?', settings)   return toboolean(res) end
is modbus device online - by benanderson_475 - 04.09.2020, 03:18
RE: is modbus device online - by Daniel - 04.09.2020, 07:29
RE: is modbus device online - by balatis - 13.09.2020, 15:08
RE: is modbus device online - by balatis - 13.09.2020, 19:28
