Sony Bravia Authentication
in case anyone can use it, Updated user library for sony tv ip control
require('json') Sony_ip = '192.168.1.6' X_Auth_Psk = "XXXXXXX9" path_system = '/sony/system' path_avContent = '/sony/avContent' path_audio = '/sony/audio' path_ircc = '/sony/IRCC' function Sony_request(host, url,  payload)     ltn12 = require('ltn12')   http = require('socket.http')   response_body = {}   res, err = http.request{     url = 'http://' .. host .. url,     method = 'POST',     headers =     {       ["Accept"] = "*/*",       ["Content-Type"] = "application/x-www-form-urlencoded",       ["X-Auth-PSK"] = X_Auth_Psk,       ["Content-Length"] = payload:len()     },       source = ltn12.source.string(payload),     sink = ltn12.sink.table(response_body)   }   if response_body then    -- log(response_body)     resp = json.encode(response_body)      resp = json.decode(resp)    -- log(resp)      if resp[2] then       resp = table.concat(resp)      resp = json.decode(resp)     else                  resp = json.decode(resp[1])     end        return resp       else     return nil, err   end end function Sony_Soap_request(host, url, IRCC)   local body, http, ltn12, sink, res, err   ltn12 = require('ltn12')   http = require('socket.http')     body = [[<?xml version="1.0"?>   <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"    s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">   <s:Body>   <u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1">   <IRCCCode>]]..IRCC..[[</IRCCCode>   </u:X_SendIRCC>   </s:Body></s:Envelope>]]     Soap_response_body = {}   res, err = http.request{     url = 'http://' .. host .. url,     method = 'POST',     headers =     {       ["Host"] = host,       ["Connection"] = "keep-alive",       ["Accept"] = "*/*",       ["Content-Type"] = "text/xml; charset=UTF-8",       ["X-Auth-PSK"] = X_Auth_Psk,       ["Content-Length"] = #body,       ["Soapaction"] = '"urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"'     },       source = ltn12.source.string(body),     sink = ltn12.sink.table(Soap_response_body)   }   if Soap_response_body then     return Soap_response_body   else     return nil, err   end end function encode_json_message(method, id, params, version)   json_msg = json.encode({       method = method,       id = id,       params = {params},       version = version         })    return json_msg end  --************************* Command  functions **************************** function Sony_pwr(state)    Sony_request(Sony_ip, path_system, encode_json_message("setPowerStatus", 55, {status = state }, "1.0")) end function Sony_set_input_hdmi1()    Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "extInput:hdmi?port=1"}, "1.0")) end function Sony_set_input_hdmi2()    Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "extInput:hdmi?port=2"}, "1.0")) end function Sony_set_input_hdmi3()    Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "extInput:hdmi?port=3"}, "1.0")) end function Sony_set_input_tv()    Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "tv:dvbt"}, "1.0")) end function Sony_set_volume(level)   res = Sony_request(Sony_ip, path_audio, encode_json_message("setAudioVolume", 98, {volume = level, ui = "on", target = ""}, "1.2")) end  function Sony_set_audio_mute(state)    Sony_request(Sony_ip, path_audio, encode_json_message("setAudioMute", 601, {status = state}, "1.0")) end --************************* Request Command functions **************************** function Sony_get_playing_content()   json_msg = encode_json_message("getPlayingContentInfo", 103, {}, "1.0")   res = Sony_request(Sony_ip, path_avContent, json_msg)   --- update obj with new value     if not res.error then -- cant call this function if the display is off res.error[2] =  Display Is Turned off   title =  res.result[1].title   programme = res.result[1].programTitle   if title then       grp.write('1/1/1', title)   end    if programme then     grp.write('1/1/2', programme)   end   end    return title, programme end function Sony_get_power_status()   pwr_res = Sony_request(Sony_ip, path_system, encode_json_message("getPowerStatus", 50, {}, "1.0"))   pwr_res = pwr_res.result[1].status --active|standby   return pwr_res end function Sony_get_volume_info()   vol_res = Sony_request(Sony_ip, path_audio, encode_json_message("getVolumeInformation", 33, {}, "1.0"))   vol_res = vol_res.result[1][1].volume -- returns tv volume level   return vol_res  end function Sony_get_remoteController_info()   res = Sony_request(Sony_ip, path_system, encode_json_message("getRemoteControllerInfo", 54, {}, "1.0"))   rc_codes = {}   res = res.result[2]   for i = 1, #res do     name = res[i].name     value = res[i].value     rc_codes[name] = value  end -- log(rc_codes)   storage.set('RC_Codes', rc_codes)   return rc_codes end function req_channel_delayed(delay)      os.sleep(delay)      Sony_get_playing_content() end function Sony_send_key(IRCC_name) -- needs to send ircc with soap command... --PartnerApp11, SyncMenu, FeaturedApp, MuteOff, MuteOn, AudioMixUp Teletext, AudioOutput_TVSpeaker, partnerApp10, BS, ActionMenu, SleepTimer --CS, AudioMixDown, TvInput, PartnerApp1, Forward, Hdmi3, DigitalToggle, Hdmi2, PartnerApp6, ApplicationLauncher, Blue, Stop, TvAntennaCable, --Wide, Help, AudioOutput_AudioSystem, VolumeDown, Hdmi1, Tv, PartnerApp20, OneTouchTimeRec, Down, PartnerApp19, PopUpMenu, FeaturedAppVOD, --Component2, Video1, Audio, Media, Digital, Num11, PartnerApp13, Mode3D, AndroidMenu, *AD, Component1, CursorRight, Enter, PhotoFrame, Sleep, --PartnerApp2, Assists, ChannelUp, Right, DOT, RecorderMenu, FootballMode, Green, PartnerApp14, GooglePlay, AudioOutput_Toggle, EPG, SubTitle, --FlashMinus, Input, PartnerApp18, PartnerApp5, ClosedCaption, PartnerApp16, PAP, PartnerApp15, PartnerApp12, PartnerApp9, TenKey, WakeUp --PartnerApp7, PartnerApp17, Next, PartnerApp4, PartnerApp3, Analog, PictureMode, STBMenu, TvSatellite, Jump, BSCS, Rec, Hdmi4, Ddata, YouTube --Mute, ChannelDown, OneTouchView, Home, AnalogRgb1, PictureOff, Num2, TvAnalog, Tv_Radio, , CursorDown, Num3, Num0, WirelessSubwoofer, Video2, --Confirm, DemoMode, Left, Num1, ShopRemoteControlForcedDynamic, FlashPlus, Display, Num6, GGuide, PartnerApp8, Prev, Num7, Num4, Play, Red, --TopMenu, Num5, Analog2, DUX, Return, VolumeUp, DpadCenter, Options, Num12, PicOff, Rewind, iManual, DemoSurround, MediaAudioTrack, Up, TvPower,   rc_codes = storage.get('RC_Codes')    if not rc_codes then     rc_codes = Sony_get_remoteController_info()   end   IRCC_key_name = rc_codes[IRCC_name]   Sony_Soap_request(Sony_ip, path_ircc, IRCC_key_name)     if IRCC_name == "ChannelDown" or IRCC_name == "ChannelUp" then     req_channel_delayed(0.5)   end end   function Sony_get_content_count()   res = Sony_request(Sony_ip, path_avContent, encode_json_message("getContentCount", 11, {source = "tv:dvbt"}, "1.1"))   return res.result[1].count end function Sony_get_content_list() local num = Sony_get_content_count()     res = Sony_request(Sony_ip, path_avContent, encode_json_message("getContentList", 88, {stIdx = 0, cnt = num, uri = "tv:dvbt"}, "1.5"))   res = res.result[1]   uri_s= {}     for i = 1, #res do     uri = res[i].uri     title = res[i].title     uri_s[title] = uri  end --- log(uri_s)   storage.set('Chan_uri', uri_s)   return uri_s end function Sony_Chanell(chan) -- chan is uri name and is returned by Sony_get_content_list() uncomment log(uri_s) above and call function Sony_get_content_list() to see what they are   uri_C = storage.get('Chan_uri')   if not uri_C then      uri_C = Sony_get_content_count()   end   res = Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = uri_C[chan]}, "1.0"))   req_channel_delayed(0.2)   return res end
Sony Bravia Authentication - by arnocl - 17.02.2020, 09:58
RE: Sony Bravia Authentication - by admin - 17.02.2020, 10:14
RE: Sony Bravia Authentication - by arnocl - 21.02.2020, 21:08
RE: Sony Bravia Authentication - by arnocl - 22.02.2020, 09:29
RE: Sony Bravia Authentication - by benanderson_475 - 23.09.2020, 03:45
RE: Sony Bravia Authentication - by Daniel - 24.07.2025, 09:10
