Tcp script event loop
You can use selectfds to check if there's data in udp/tcp socket or when tcp socket is closed.
--log in-- function log_in()   local ip, port = "192.168.1.61", 1918   client = assert(require('socket').tcp())   client:connect(ip, port)   client:settimeout(0.5)   log("Connecting to Alarm at ip:" .. ip .. ' port: '.. tostring(port)..' at '.. os.date("%H:%M:%S"))   -- log("logging Out of alarm")   client:send(string.char(0x49,0x43,0x08,0x00,0x00,0x00,0x00,0x03))   -- log("logging In")   client:send(string.char(0x49,0x43,0x0D,0x00,0x00,0x00,0x00,0x02,0x01,0x02,0x03,0x04,0xFF))   -- log("Setting alarm timeout")   client:send(string.char(0x49,0x43,0x0A,0x00,0x00,0x00,0x00,0x04,0x70,0x17))   --  log("Turning alarm events on")   client:send(string.char(0x49,0x43,0x0A,0x00,0x00,0x00,0x00,0x06,0x01,0x01)) end log_in_time = os.time() + 900 log_in() --udp server for recieving commands from event script if not server then   server = require('socket').udp()   server:setsockname('127.0.0.1', 5432) end sfd = socket.fdmaskset(server:getfd(), 'r') cfd = socket.fdmaskset(client:getfd(), 'r') while true do   res, sstat, cstat = socket.selectfds(10, sfd, cfd)   if res then     if sstat then       cmd = server:receive()       if cmd then         log("udp server message", cmd)       end     end     if cstat then       rx, err = client:receive()       if rx then         log("tcp client message", rx)       else         log_in_time = 0         log("tcp client error", err)       end     end   end   if os.time() > log_in_time then     client:close()     log_in()     log_in_time = os.time() + 900   end end
Tcp script event loop - by benanderson_475 - 21.09.2020, 04:58
RE: Tcp script event loop - by admin - 21.09.2020, 07:24
RE: Tcp script event loop - by admin - 28.09.2020, 06:31
RE: Tcp script event loop - by admin - 29.09.2020, 07:48
