MikroTik API Lua library
Use attached code to create a user library named mikrotik.
Make sure that your router is running at least v6.43.
It is recommended to create a separate user for api access, possibly with limited read-only access if you don't need to change anything on the router remotely.
Example:
mt, err = require('user.mikrotik').new('192.168.1.1') if mt then   res, err = mt:login('api', '123456') -- user api, pass 123456   if res then     -- get wireless registration table     res, err = mt:readlist('/interface/wireless/registration-table/print')     log(res)   else     log('login failed', tostring(err))   end   mt:close() else   log('connect failed', tostring(err)) end
.lua   mikrotik.lua (Size: 3.85 KB / Downloads: 54)
MikroTik API Lua library - by admin - 20.10.2020, 06:57
RE: MikroTik API Lua library - by FatMax - 20.10.2020, 11:48
RE: MikroTik API Lua library - by admin - 20.10.2020, 12:13
RE: MikroTik API Lua library - by DGrandes - 03.12.2020, 17:45
RE: MikroTik API Lua library - by admin - 04.12.2020, 07:35
RE: MikroTik API Lua library - by DGrandes - 07.12.2020, 13:11
RE: MikroTik API Lua library - by admin - 07.12.2020, 13:49
RE: MikroTik API Lua library - by DGrandes - 07.12.2020, 15:03
RE: MikroTik API Lua library - by admin - 09.12.2020, 07:19
RE: MikroTik API Lua library - by DGrandes - 09.12.2020, 08:09
RE: MikroTik API Lua library - by FatMax - 07.01.2021, 23:20
RE: MikroTik API Lua library - by Igori - 10.01.2021, 15:45
RE: MikroTik API Lua library - by admin - 11.01.2021, 08:07
RE: MikroTik API Lua library - by Igori - 11.01.2021, 19:50
RE: MikroTik API Lua library - by edgars - 26.08.2021, 08:28
