Help with timer/time in LUA script
Create a scheduled scripts that runs every minute.
Change group addresses as needed:
1/1/1 - mode (2 = auto)
1/1/2 - forecast (true/false)
1/1/3 - temperature value
1/1/4 - output control
To simplify things the output will turn on at 0 minutes of every hour if needed and will turn off after X minutes depending on the current temperature.
mode = grp.getvalue('1/1/1') if mode ~= 2 then   return end forecast = grp.getvalue('1/1/2') temperature = grp.getvalue('1/1/3') if not forecast or temperature > 4 then   offtime = 0 -- 0..4 elseif temperature >= 0 then   offtime = 25 -- -4..0 elseif temperature >= -4 then   offtime = 35 -- -8..-4 elseif temperature >= -8 then   offtime = 50 -- lower than -8 else   offtime = 60 end min = os.date('*t').min value = min < offtime grp.checkwrite('1/1/4', value)
RE: Help with timer/time in LUA script - by admin - 26.10.2020, 11:43
