04.11.2020, 10:55
(04.11.2020, 07:48)admin Wrote: To dim a color your need to convert RGB to HSV, change V up/down and then convert back to RGB.Thank you very much! So my only doubt is which group addresses I need to define
Here are the functions that you can use.
Code:function rgbtohsv(r, g, b) local max, min, d, h, s, v max = math.max(r, g, b) min = math.min(r, g, b) d = max - min s = max == 0 and 0 or (d / max) v = max / 255 if max == min then h = 0 elseif max == r then h = (g - b) + d * (g < b and 6 or 0) h = h / (6 * d) elseif max == g then h = (b - r) + d * 2 h = h / (6 * d) elseif max == b then h = (r - g) + d * 4 h = h / (6 * d) end return h, s, v end function hsvtorgb(h, s, v) local r, g, b, i, f, p, q, t, z i = math.floor(h * 6) f = h * 6 - i p = v * (1 - s) q = v * (1 - f * s) t = v * (1 - (1 - f) * s) z = i % 6 if z == 0 then r = v g = t b = p elseif z == 1 then r = q g = v b = p elseif z == 2 then r = p g = v b = t elseif z == 3 then r = p g = q b = v elseif z == 4 then r = t g = p b = v elseif z == 5 then r = v g = p b = q end r = math.round(r * 255) g = math.round(g * 255) b = math.round(b * 255) return r, g, b end function rgbstep(r, g, b, up, step) local h, s, v = rgbtohsv(r, g, b) local v2 = up and math.min(1, v + step) or math.max(0, v - step) if v == v2 then return end return hsvtorgb(h, s, v2) end
rgbstep(r, g, b, up, step) can perform up/down step of current RGB value.
arguments:rgbstep will return new RGB values but it might also return nil when further step is not possible.
- r, g, b - color components in 0..255 range
- up - true = step up / false = step down
- step - step size, V range is 0..1 so the step should be something like 0.1 or 0.05 depending on how many total steps you want
Code:-- values from split RGB value r = 127 g = 255 b = 10 -- step down up = false -- maximum 20 steps between min and max step = 0.05 r, g, b = rgbstep(r, g, b, up, step) if r then -- write new values else -- stop dimming end
