16.11.2020, 08:31
Here's an example that can be used as a starting point.
It should be modified to fetch the data remotely. It already converts CSV into correct data format for the graph library.
graph should only be created once, to update it with new data use this:
$(function() {
var csv = `11-05-20 16:01:06;0,51
11-05-20 16:01:17;0,44
11-05-20 16:01:29;0,48
11-05-20 16:01:40;0,48
11-05-20 16:01:52;0,53
11-05-20 16:02:03;0,48
11-05-20 16:02:15;0,45
11-05-20 16:02:26;0,49
11-05-20 16:02:38;0,47
11-05-20 16:02:49;0,47`;
var data = [];
// convert CSV to correct data format
$.each(csv.split('\n'), function(_, line) {
var items = line.split(';')
, d = items[0].replace(/(\d+)\-(\d+)\-(\d+) (.*)/, '20$3-$2-$1 $4')
, n = items[1].replace(',', '.');
data.push([
new Date(d),
Number(n)
// create element for graph display, add to plan #1
var el = $('<div></div>').css({
position: 'absolute',
width: 500,
height: 300,
left: 250,
top: 380
}).appendTo('#plan-1').get(0);
// create graph instance
var graph = new Dygraph(el, data, {
labels: [ '', 'My data' ],
xAxisLabelWidth: 60
});graph should only be created once, to update it with new data use this:
graph.updateOptions({ file: data });
