Script execution priority
Hi everybody!  Big Grin
I have a big problem, with the execution of my project and I hope you will have some advise.
I have to read/write datas from/to 4 different PLCs in the same Modbus RTU network. There are 14 different script (6 resident, 6 event and 2 scheduler) that exchange data via modbus RTU.
To avoid that one or more script start before the finish of the script that is in execution, I use this code:
repeat  tmp = storage.get("Modbus")  if (tmp == nil or tmp == 0) then    storage.set("Modbus", 1)    continue = true    alert("--SCRIPT--Dati CT -> START")    --This line is used for debuggig purpose  else    continue = false    os.sleep(0.2)  end until (continue) --My script code that start communication with one modbus slave PLC
Sometimes it happened that 2 or more script started at the same time and they were both executed. This couse timeout and wrong slave errors because scripts set the communication with different slaves.
I hope you will understand my problem, I'm not very good in english Tongue
Mirco
Script execution priority - by Mirco - 13.09.2016, 07:09
RE: Script execution priority - by admin - 13.09.2016, 07:17
RE: Script execution priority - by Mirco - 13.09.2016, 07:38
RE: Script execution priority - by admin - 14.09.2016, 08:40
RE: Script execution priority - by Mirco - 16.09.2016, 05:58
RE: Script execution priority - by admin - 16.09.2016, 06:45
RE: Script execution priority - by Mirco - 02.12.2016, 14:53
RE: Script execution priority - by admin - 02.12.2016, 16:38
