Renewing SSL certificate
The script that you've provided won't work on LM. At this point it's not possible to fully automate this process without an external server. We have plans to add a service that uses LetsEncrypt for fully automated certificate issue and renewal but I can't tell you when it's going live.
For now you can replace the current key/certificate like this:
require('json') -- data from privkey.pem key = [[ -----BEGIN PRIVATE KEY----- ... -----END PRIVATE KEY----- ]] -- data from fullchain.pem crt = [[ -----BEGIN CERTIFICATE----- ... -----END CERTIFICATE----- -----BEGIN CERTIFICATE----- ... -----END CERTIFICATE----- ]] json.data = function()   return {     values = {       mode = 'set',       key = key,       crt = crt,     }   } end stat, res = pcall(dofile, '/lib/flashsys/httpd_crt/save.lua') if stat then   res = json.pdecode(res)   log(res)   os.execute('/etc/init.d/nginx reload') else   log('error', res) end
Renewing SSL certificate - by buuuudzik - 09.12.2020, 23:02
RE: Renewing SSL certificate - by admin - 11.12.2020, 07:39
RE: Renewing SSL certificate - by admin - 06.05.2022, 11:12
RE: Renewing SSL certificate - by admin - 06.05.2022, 11:33
RE: Renewing SSL certificate - by Leo681 - 06.06.2023, 15:23
