11.12.2020, 09:56
(This post was last modified: 11.12.2020, 09:57 by davidchispas.)
(11.12.2020, 08:31)Daniel. Wrote: You can make a backup and then try the scan, when you restore all will be back. Here we need to find where is the problem.Hello Daniel,
Did you try this again https://forum.logicmachine.net/showthrea...2#pid19702 with new PSU? Can you try both interfaces?
Yes, I have tried and the record has been the same. (TX error).
I have tried all the scanning modalities in the past week, with five different ballasts. Doing a complete search only found two ballasts of this type, https://www.osram.es/ecat/Reguladores%20...1_1119972/. And they are the ones that are working on that Dali line right now.
Now in my test workshop, I am running the search for the same ballasts used previously without success, with a CANx LM and its CANx DALI gateway, the partial search has been successful.
I have made the purchase of another LM DALI to replace it, I will replace it and test if there is success.
I am honestly surprised that some ballasts find them and others do not. The wiring is fine and so is the setup. My question is if the latest updates could affect my LM.
I have more installations with the same LM and the same ballasts and I have not had a search problem.
