DALI PROBLEM
#46
(15.12.2020, 15:42)Daniel. Wrote: Check minimum dimming value, it is parameter of the ballast, If you can change it lower then you will be able to go lower.
Hello Daniel, I understand that this parameter is not generated from LM, it is something internal to the ballast. or am I wrong? I have a Mean Well ELG-240H-24B, with the naked eye I can't do anything to it.
DALI PROBLEM - by davidchispas - 19.06.2019, 09:21
RE: DALI PROBLEM - by admin - 19.06.2019, 09:37
RE: DALI PROBLEM - by khalil - 08.07.2021, 13:44
RE: DALI PROBLEM - by davidchispas - 20.06.2019, 15:19
RE: DALI PROBLEM - by Daniel - 21.06.2019, 07:17
RE: DALI PROBLEM - by davidchispas - 21.06.2019, 12:21
RE: DALI PROBLEM - by admin - 21.06.2019, 07:46
RE: DALI PROBLEM - by admin - 21.06.2019, 13:21
RE: DALI PROBLEM - by davidchispas - 24.06.2019, 09:43
RE: DALI PROBLEM - by davidchispas - 02.07.2019, 11:03
RE: DALI PROBLEM - by admin - 02.07.2019, 12:37
RE: DALI PROBLEM - by davidchispas - 02.07.2019, 12:46
RE: DALI PROBLEM - by admin - 02.07.2019, 12:54
RE: DALI PROBLEM - by davidchispas - 04.07.2019, 07:33
RE: DALI PROBLEM - by davidchispas - 08.07.2019, 07:36
RE: DALI PROBLEM - by admin - 04.07.2019, 07:56
RE: DALI PROBLEM - by admin - 08.07.2019, 07:44
RE: DALI PROBLEM - by davidchispas - 08.07.2019, 09:24
RE: DALI PROBLEM - by davidchispas - 09.12.2020, 09:15
RE: DALI PROBLEM - by admin - 09.12.2020, 09:31
RE: DALI PROBLEM - by davidchispas - 09.12.2020, 09:48
RE: DALI PROBLEM - by admin - 09.12.2020, 09:49
RE: DALI PROBLEM - by davidchispas - 09.12.2020, 10:04
RE: DALI PROBLEM - by admin - 09.12.2020, 11:21
RE: DALI PROBLEM - by davidchispas - 09.12.2020, 11:24
RE: DALI PROBLEM - by admin - 09.12.2020, 11:56
RE: DALI PROBLEM - by davidchispas - 09.12.2020, 14:23
RE: DALI PROBLEM - by davidchispas - 10.12.2020, 10:11
RE: DALI PROBLEM - by Daniel - 09.12.2020, 14:48
RE: DALI PROBLEM - by Erwin van der Zwart - 09.12.2020, 19:50
RE: DALI PROBLEM - by Daniel - 10.12.2020, 08:12
RE: DALI PROBLEM - by admin - 10.12.2020, 10:12
RE: DALI PROBLEM - by davidchispas - 10.12.2020, 10:50
RE: DALI PROBLEM - by Daniel - 10.12.2020, 10:19
RE: DALI PROBLEM - by admin - 10.12.2020, 13:54
RE: DALI PROBLEM - by davidchispas - 10.12.2020, 15:00
RE: DALI PROBLEM - by Daniel - 11.12.2020, 08:21
RE: DALI PROBLEM - by davidchispas - 11.12.2020, 08:28
RE: DALI PROBLEM - by Daniel - 11.12.2020, 08:31
RE: DALI PROBLEM - by davidchispas - 11.12.2020, 09:56
RE: DALI PROBLEM - by Daniel - 11.12.2020, 10:08
RE: DALI PROBLEM - by davidchispas - 11.12.2020, 11:02
RE: DALI PROBLEM - by Daniel - 11.12.2020, 11:04
RE: DALI PROBLEM - by davidchispas - 15.12.2020, 15:39
RE: DALI PROBLEM - by Daniel - 15.12.2020, 15:42
RE: DALI PROBLEM - by davidchispas - 16.12.2020, 07:38
RE: DALI PROBLEM - by admin - 15.12.2020, 15:56
RE: DALI PROBLEM - by admin - 16.12.2020, 07:58
RE: DALI PROBLEM - by davidchispas - 16.12.2020, 11:10
RE: DALI PROBLEM - by admin - 16.12.2020, 11:11
RE: DALI PROBLEM - by admin - 09.07.2021, 07:38
RE: DALI PROBLEM - by puntukas - 18.11.2021, 14:11
RE: DALI PROBLEM - by Daniel - 18.11.2021, 14:20
RE: DALI PROBLEM - by puntukas - 18.11.2021, 16:38
RE: DALI PROBLEM - by Daniel - 18.11.2021, 16:53
RE: DALI PROBLEM - by puntukas - 18.11.2021, 17:20
RE: DALI PROBLEM - by eilert - 25.01.2022, 14:46
RE: DALI PROBLEM - by Daniel - 25.01.2022, 14:59
