Is there any way that I can get DHCP table?
(31.12.2020, 13:09)admin Wrote: This has to be done on your router. See if you can enable a static DHCP entry for a certain MAC.
How can some software like Fing on mobile or Angry IP Scanner can scan all IP in the network so fast, They send some UDP packet and get response I think?. I use packet capture and see that they send request to port 137 (NetBios) of all the IP from .1 to .255 and see the response to see if the IP is available. I want to do something like that, is it possible
And the device will be move from house to house, it means that I should write a code to detect the device so I don't need to setup every router that it will be install.
Currently I use this code to ping to every IP from 1 to 255 and find it but it's way too slow. So it's best if I can find IP of all device on the network, and look for it by it's name or MAC but I dont know how to do
for i = 1, 255 do   ip = '192.168.1.' .. i   res = os.execute('ping -c 2 -W 1 ' .. ip)   if res == 0 then     url='http://'..ip..'/httpapi.asp?command=getPlayerStatus'     require('socket.http')     res, err = socket.http.request(url)     if res ~= nil then       t1, t2 = string.find(res, 'Artist')       if t1 ~= nil then           --my code       break    end   end end
RE: Is there any way that I can get DHCP table? - by pouralise - 31.12.2020, 13:14
