MikroTik API Lua library
(20.10.2020, 12:13)admin Wrote: Unify API is done via HTTP requests. You need to send one request for login, get a cookie value from it and pass this cookie to any other requests after that.
Here's an example that can be used as a starting point: https://forum.logicmachine.net/showthrea...3#pid18233
The difference is that this example uses standard POST whereas Unify communicates via raw POST / JSON. Like this:
http = require('socket.http') json = require('json') login_url = 'https://IP:8443/api/login' data = json.encode({   username = user,   password = pass, }) res, err, hdrs = http.request(login_url, data) log(res, err, hdrs)
Finally got around to get credentials and actually test this out. With the help from your example I managed to fetch a list over active clients. Thank you very much!
MikroTik API Lua library - by admin - 20.10.2020, 06:57
RE: MikroTik API Lua library - by FatMax - 20.10.2020, 11:48
RE: MikroTik API Lua library - by admin - 20.10.2020, 12:13
RE: MikroTik API Lua library - by DGrandes - 03.12.2020, 17:45
RE: MikroTik API Lua library - by admin - 04.12.2020, 07:35
RE: MikroTik API Lua library - by DGrandes - 07.12.2020, 13:11
RE: MikroTik API Lua library - by admin - 07.12.2020, 13:49
RE: MikroTik API Lua library - by DGrandes - 07.12.2020, 15:03
RE: MikroTik API Lua library - by admin - 09.12.2020, 07:19
RE: MikroTik API Lua library - by DGrandes - 09.12.2020, 08:09
RE: MikroTik API Lua library - by FatMax - 07.01.2021, 23:20
RE: MikroTik API Lua library - by Igori - 10.01.2021, 15:45
RE: MikroTik API Lua library - by admin - 11.01.2021, 08:07
RE: MikroTik API Lua library - by Igori - 11.01.2021, 19:50
RE: MikroTik API Lua library - by edgars - 26.08.2021, 08:28
