Energy Management by Wiser
(14.01.2021, 08:36)Daniel. Wrote: You need to specify in more details which wiser you have in mind as there is lots of them in SE portfolio.
Daniel;
Hardware:
2 x 12 Schneider actuators with current detection
1 x Schneider Dali gateway
1 x Schneider KNX Wiser (HL / LM) logics module (KNX TP / LAN IP / 1 x Modbus used for  Ventilation unit)
2 x Schneider KNX power supply
23 x Schneider circuit breakers 15A - 25A 230v
1 x Mains 3-phase 63A 230v
Per now there are NO PowerTags or other devices (except the actuators) installed to track power consumption per circuit. It would be very interesting to get power consumption with trends for several of the circuits. In example Hot-tub, water heater, washing equipment, heated floors (Actuator measure), heat pump etc. Maybe around 10 circuits is sufficient.
As I am starting from scratch with power measuring; -  it would be great to choose the right solution from the start. Easily installed, user friendly data harvesting (in Wiser KNX), sensible pricing and easily integrated into the KNX Wiser for visualization, trending and warnings. What would be recommended solution for a smooth integration to the KNX WISER ( Logic machine? I am open to look at other brands and solution than those from Schneider catalog. Simple integration is key.
Energy Management by Wiser - by baggins - 23.03.2019, 14:40
RE: Energy Management by Wiser - by baggins - 23.03.2019, 18:24
RE: Energy Management by Wiser - by AlexLV - 24.03.2019, 06:26
RE: Energy Management by Wiser - by AlexLV - 26.03.2019, 07:09
RE: Energy Management by Wiser - by Daniel - 14.07.2019, 09:23
RE: Energy Management by Wiser - by domotiqa - 24.10.2019, 14:20
RE: Energy Management by Wiser - by stemic01 - 13.01.2021, 19:51
RE: Energy Management by Wiser - by Daniel - 14.01.2021, 08:36
RE: Energy Management by Wiser - by stemic01 - 14.01.2021, 11:45
RE: Energy Management by Wiser - by Daniel - 14.01.2021, 12:29
RE: Energy Management by Wiser - by Daniel - 09.01.2023, 10:20
RE: Energy Management by Wiser - by AlexLV - 11.01.2023, 23:12
RE: Energy Management by Wiser - by domotiqa - 25.08.2023, 14:04
