04.02.2021, 13:37
(16.11.2020, 08:31)admin Wrote: Here's an example that can be used as a starting point.
It should be modified to fetch the data remotely. It already converts CSV into correct data format for the graph library.
Code:$(function() { var csv = `11-05-20 16:01:06;0,51 11-05-20 16:01:17;0,44 11-05-20 16:01:29;0,48 11-05-20 16:01:40;0,48 11-05-20 16:01:52;0,53 11-05-20 16:02:03;0,48 11-05-20 16:02:15;0,45 11-05-20 16:02:26;0,49 11-05-20 16:02:38;0,47 11-05-20 16:02:49;0,47`; var data = []; // convert CSV to correct data format $.each(csv.split('\n'), function(_, line) { var items = line.split(';') , d = items[0].replace(/(\d+)\-(\d+)\-(\d+) (.*)/, '20$3-$2-$1 $4') , n = items[1].replace(',', '.'); data.push([ new Date(d), Number(n) ]); }); // create element for graph display, add to plan #1 var el = $('<div></div>').css({ position: 'absolute', width: 500, height: 300, left: 250, top: 380 }).appendTo('#plan-1').get(0); // create graph instance var graph = new Dygraph(el, data, { labels: [ '', 'My data' ], xAxisLabelWidth: 60 }); });
graph should only be created once, to update it with new data use this:
Code:graph.updateOptions({ file: data });
Hello Admin
Is it possible to use this way to show values from object logs as trend/curve?
Best Regards,
