Receive UDP string
Hi I'm after a similar function but require a TCP connection to ensure retransmission of any lost packets. Is there an example of a TCP server?
is there anything wrong with this from the lua socket example? can it be improved for the lm?
if not server then -- load namespace socket = require("socket") -- create a TCP socket and bind it to the local host, at any port server = assert(socket.bind("*", 7777)) -- find out which port the OS chose for us ip, port = server:getsockname() -- print a message informing what's up log("Please telnet to localhost on port "..port) log("After connecting, you have 10s to enter a line to be echoed") -- loop forever waiting for clients while 1 do   -- wait for a connection from any client   local client = server:accept()   -- make sure we don't block waiting for this client's line   client:settimeout(10)   -- receive the line data, err = client:receive()     log(data)   -- done with client, close the object   client:close() end end
Receive UDP string - by leonidas - 24.08.2017, 13:16
RE: Receive UDP string - by admin - 24.08.2017, 17:51
RE: Receive UDP string - by AlexLV - 24.08.2017, 22:47
RE: Receive UDP string - by leonidas - 28.08.2017, 05:25
RE: Receive UDP string - by admin - 28.08.2017, 08:54
RE: Receive UDP string - by AlexLV - 04.09.2017, 08:41
RE: Receive UDP string - by Diggerz - 15.02.2021, 01:38
RE: Receive UDP string - by admin - 15.02.2021, 07:46
RE: Receive UDP string - by Diggerz - 18.02.2021, 08:56
RE: Receive UDP string - by admin - 18.02.2021, 08:58
