PID Problem
Hello, admin,
Thanks for the response!
What do you mean by kp value too low? As I've mentioned before, I'm trying to achieve (6K/150min) control, which would translate to kp value being 0.16 (1/6K-->0.16), or I'm calculating something wrong?
I've tried putting in kp equal to 1, but all outputs still give out 0. Current temp - 22.5C, setpoint - 23C.
I'm trying to simulate different controls, output isn't connected to valves right now, but I just need some information from trend logs for now.
I also added 1sec delay after each run:
local P_value = 6 local I_value = 150 local kp_value = 1 local ki_value = 0.0017 local delay = 1 if not P then P = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_P_Output',     kp = kp_value,     ki = 0,     kd = 0 }) PI = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PI_Output',     kp = kp_value,     ki = ki_value,     kd = 0 }) PID1 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID1_Output',     kp = kp_value,     ki = ki_value,     kd = 0.1 }) PID2 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID2_Output',     kp = kp_value,     ki = ki_value,     kd = 0.2 }) PID3 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID3_Output',     kp = kp_value,     ki = ki_value,     kd = 0.3 })    PID4 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID4_Output',     kp = kp_value,     ki = ki_value,     kd = 0.4 }) PID5 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID5_Output',     kp = kp_value,     ki = ki_value,     kd = 0.5 }) PID6 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID6_Output',     kp = kp_value,     ki = ki_value,     kd = 0.6 }) PID7 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID7_Output',     kp = kp_value,     ki = ki_value,     kd = 0.7 }) PID8 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID8_Output',     kp = kp_value,     ki = ki_value,     kd = 0.8 }) PID9 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID9_Output',     kp = kp_value,     ki = ki_value,     kd = 0.9 }) PID10 = PID:init({     current = 'RTC05_Current_Temperature',     setpoint = 'RTC05_Setpoint_Temperature_Status',     output = 'BD_PID10_Output',     kp = kp_value,     ki = ki_value,     kd = 1 }) end P:run() os.sleep(delay) PI:run() os.sleep(delay) PID1:run() os.sleep(delay) PID2:run() os.sleep(delay) PID3:run() os.sleep(delay) PID4:run() os.sleep(delay) PID5:run() os.sleep(delay) PID6:run() os.sleep(delay) PID7:run() os.sleep(delay) PID8:run() os.sleep(delay) PID9:run() os.sleep(delay) PID10:run()
Update: Okay, so I've set ki to 1 aswell, and now PI and PID controllers give out 11 percent, and add 10 percent every minute, which is way too fast. How do I achieve (6K/150min) control? And why P controller still gives out 0?
PID Problem - by MantasJ - 13.02.2021, 14:56
RE: PID Problem - by MantasJ - 13.02.2021, 16:11
RE: PID Problem - by admin - 15.02.2021, 10:30
RE: PID Problem - by MantasJ - 15.02.2021, 12:07
RE: PID Problem - by admin - 15.02.2021, 12:25
RE: PID Problem - by MantasJ - 15.02.2021, 12:41
RE: PID Problem - by admin - 15.02.2021, 14:06
