Modbus TCP connection datakom d-200 mk2
Seems to be a networking issue of some kind. Try running the same script with debug mode enabled and post what you get in Logs tab.
if not mb then   require('luamodbus')   mb = luamodbus.tcp()   mb:setresponsetimeout(5)   mb:open('10.36.0.25', 502)   res, err = mb:connect()   if res then          buffer = {}     mb:setdebug(function(msg)       buffer[ #buffer + 1 ] = msg     end)   else     log('modbus connect failed ' .. tostring(err))     mb:close()     mb = nil   end end if mb then   reg10240, reg10241, reg10242, reg10243, reg10244, reg10245, reg10246, reg10247 = mb:readregisters(10240, 8)      if reg10240 then     mains_l1_voltage = reg10240 / 10     mains_l2_voltage = reg10242 / 10     mains_l3_voltage = reg10244 / 10     genset_l1_voltage = reg10246 / 10     log('voltage values', mains_l1_voltage, mains_l2_voltage, mains_l3_voltage, genset_l1_voltage)     log(table.concat(buffer))     buffer = {}   else     log('modbus read failed ' .. tostring(reg10241))     mb:close()     mb = nil   end end
RE: Modbus TCP connection datakom d-200 mk2 - by admin - 23.02.2021, 09:09
