TELEGRAM APP
(01.06.2020, 14:29)Daniel. Wrote: It was explained here https://forum.logicmachine.net/showthrea...13#pid2513 but lets make a clear version:
1. Install Telegram app
2. Find BotFather or go here https://t.me/botfather
3. Once in BotFather type /newbot and follow instructions. As a result you will get your token and your own bot link like t.me/yourname_bot Click on the link and type any message there
4. Open browser (preferably Firefox as it converts JSON automatically) and go here https://api.telegram.org/bot<token>/getUpdates. Replace <token> with your token. As a result you should have something like that. Save your chat ID
5. Create a user library called telegram. paste this code and replace your token and chat ID
function telegram(message)   local url = 'https://api.telegram.org/bot' .. token .. '/sendMessage'   local data = 'chat_id=' .. chat_id .. '&text=' .. socket.url.escape(message)   return ssl.https.request(url, data) end
6. Create an event based script and use this code to send message to Telegram app:
require("user.telegram") message = 'test message' res, err = telegram(message) log(res, err)
hello
I use SL V2.6.0
I follow the steps but I got this error:
User library telegram:6: attempt to index global 'socket' (a nil value)
stack traceback:
User library telegram:6: in function 'telegram'
User script:5: in main chunk
Best Regards,
TELEGRAM APP - by Hosutech - 01.06.2020, 11:15
RE: TELEGRAM APP - by Daniel - 01.06.2020, 14:29
RE: TELEGRAM APP - by JRP - 03.06.2020, 17:18
RE: TELEGRAM APP - by JRP - 11.07.2020, 18:47
RE: TELEGRAM APP - by khalil - 04.03.2021, 10:36
RE: TELEGRAM APP - by olegrz - 04.09.2022, 12:32
RE: TELEGRAM APP - by Daniel - 03.06.2020, 18:02
RE: TELEGRAM APP - by JRP - 03.06.2020, 18:27
RE: TELEGRAM APP - by Daniel - 03.06.2020, 18:40
RE: TELEGRAM APP - by JRP - 03.06.2020, 18:57
RE: TELEGRAM APP - by Erwin van der Zwart - 03.06.2020, 21:06
RE: TELEGRAM APP - by olegrz - 06.01.2024, 17:51
RE: TELEGRAM APP - by olegrz - 07.01.2024, 09:09
RE: TELEGRAM APP - by admin - 04.06.2020, 04:36
RE: TELEGRAM APP - by baggins - 04.06.2020, 10:54
RE: TELEGRAM APP - by JRP - 04.06.2020, 07:35
RE: TELEGRAM APP - by admin - 04.06.2020, 11:17
RE: TELEGRAM APP - by phongvucba - 04.08.2020, 09:03
RE: TELEGRAM APP - by Daniel - 04.08.2020, 09:06
RE: TELEGRAM APP - by admin - 04.03.2021, 10:38
RE: TELEGRAM APP - by khalil - 04.03.2021, 10:44
RE: TELEGRAM APP - by khalil - 04.03.2021, 14:18
RE: TELEGRAM APP - by admin - 04.03.2021, 17:17
RE: TELEGRAM APP - by khalil - 08.03.2021, 14:28
RE: TELEGRAM APP - by admin - 09.03.2021, 07:08
RE: TELEGRAM APP - by khalil - 09.03.2021, 08:42
RE: TELEGRAM APP - by admin - 09.03.2021, 08:45
RE: TELEGRAM APP - by khalil - 09.03.2021, 09:24
RE: TELEGRAM APP - by edgars - 09.02.2022, 11:49
RE: TELEGRAM APP - by admin - 05.09.2022, 06:17
RE: TELEGRAM APP - by olegrz - 05.09.2022, 09:04
RE: TELEGRAM APP - by Daniel - 02.02.2023, 18:08
RE: TELEGRAM APP - by David - 26.04.2023, 07:28
RE: TELEGRAM APP - by admin - 26.04.2023, 07:28
RE: TELEGRAM APP - by David - 26.04.2023, 07:33
