Home Connect
I've gotten a bit further here. The HC API requires me to log in to my account and accept the API connection. I have made that part of the script, but the question is how to get this part of the script only to run once when needed. The return is a device_code and a url for logging in to HC account. If the function is run every cycle, the verification url changes, and the device_code also.
Documentation: https://api-docs.home-connect.com/author...evice-flow
function GetDeviceCode()   local request_code_url = "https://api.home-connect.com/security/oauth/device_authorization"   local response_body = {}   local export_data = {}     local request_body = "client_id=" .. client_id .. "&scope=" .. scope   local body, code, hdrs, stat = https.request   {     url = request_code_url;     method = "POST";     headers =     {       ["Content-Type"] = "application/x-www-form-urlencoded";       ["Content-Length"] = #request_body;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   log(code)    if code == 200 then     response_decode = json.decode(table.concat(response_body))     log(response_decode)     sleep = response_decode["interval"]     return response_decode["device_code"]  end end
response_decode:
* table: ["expires_in"]   * number: 600 ["verification_uri_complete"]   * string: https://api.home-connect.com/security/oauth/device_verify?user_code=xxxx-xxxx ["verification_uri"]   * string: https://api.home-connect.com/security/oauth/device_verify ["user_code"]   * string: xxxx-xxxx ["device_code"]   * string: xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx ["interval"]   * number: 5
Home Connect - by tomnord - 24.11.2020, 21:00
RE: Home Connect - by Erwin van der Zwart - 25.11.2020, 22:15
Home Connect - by tomnord - 11.02.2021, 21:17
RE: Home Connect - by admin - 12.02.2021, 12:17
RE: Home Connect - by tomnord - 08.03.2021, 20:03
RE: Home Connect - by admin - 09.03.2021, 06:54
RE: Home Connect - by tomnord - 09.03.2021, 15:32
RE: Home Connect - by Daniel - 09.03.2021, 15:44
