TELEGRAM APP
#23
(09.03.2021, 07:08)admin Wrote: Here's a working example. Change token and chat_id. filedata is a string containing your CSV data.
require('ssl.https') token = '9876543210:abcdefgh' chat_id = '1234567890' filedata = [[ col_a,col_b,col_c 1,2,3 4,5,6 ]] params = {   {     name = 'chat_id',     value = chat_id,   },   {     name = 'document',     filename = 'report.csv',     ctype = 'text/csv',     value = filedata,   } } boundary = os.date('%d%m%Y%H%M%S') body = { '--' .. boundary } for _, param in ipairs(params) do   line = string.format('Content-Disposition: form-data; name=%q', param.name)   if param.filename then     line = string.format('%s; filename=%q', line, param.filename)   end   body[ #body + 1 ] = line   if param.ctype then     body[ #body + 1 ] = string.format('Content-Type: %s', param.ctype)   end   body[ #body + 1 ] = ''   body[ #body + 1 ] = param.value   body[ #body + 1 ] = '--' .. boundary end -- last boundary body[ #body ] = body[ #body ] .. '--' -- empty line at the end body[ #body + 1 ] = '' bodydata = table.concat(body, '\r\n') resp = {} log(   ssl.https.request({     url = 'https://api.telegram.org/bot' .. token .. '/sendDocument',     sink = ltn12.sink.table(resp),     method = 'POST',     source = ltn12.source.string(bodydata),     headers = {       ['content-length'] = #bodydata,       ['content-type'] = 'multipart/form-data; boundary=' .. boundary     }   }) ) log(table.concat(resp))
thank you admin for your time
I want to insert the log object script such as this one
I tried but I still not tough in LUA
logtime = os.time() - 60 * 60
-- Список  объектов по id
objects = {}
-- получаем объекты по которым ведется запись действий
query = 'SELECT address, datatype, name FROM objects WHERE disablelog=0'
for _, object in ipairs(db:getall(query)) do
 objects[ tonumber(object.address) ] = {
   datatype = tonumber(object.datatype),
   name = tostring(object.name or ''),
-- csv буфер
buffer = {'"date","address","name","value"'}
-- получаем список действий по объектам
query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC'
for _, row in ipairs(db:getall(query, logtime)) do
 object = objects[ tonumber(row.address) ]
 -- находим соответствие между объектом и  типом события – запись по групповому адресу
 if object and row.eventtype == 'write' then
   datatype = object.datatype
   -- проверяем что тип данных установлен
   if datatype then
     -- раскодируем данные
     data = knxdatatype.decode(row.datahex, datatype)
     -- удаляем null символы из char/string типов
     if datatype == dt.char or datatype == dt.string then
       data = data:gsub('%z+', '')
     -- конвертируем date в формат DD.MM.YYYY
     elseif datatype == dt.date then
       data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year)
     -- time в HH:MM:SS
     elseif datatype == dt.time then
       data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second)
     data = ''
   -- форматируем csv колонки
   logdate = os.date('%Y.%m.%d %H:%M:%S', row.logtime)
   csv = string.format('%q,%q,%q,%q', logdate, knxlib.decodega(row.address), object.name, tostring(data))
   -- добавляем в  buffer данные
   table.insert(buffer, csv)
Best Regards,
TELEGRAM APP - by Hosutech - 01.06.2020, 11:15
RE: TELEGRAM APP - by Daniel - 01.06.2020, 14:29
RE: TELEGRAM APP - by JRP - 03.06.2020, 17:18
RE: TELEGRAM APP - by JRP - 11.07.2020, 18:47
RE: TELEGRAM APP - by khalil - 04.03.2021, 10:36
RE: TELEGRAM APP - by olegrz - 04.09.2022, 12:32
RE: TELEGRAM APP - by Daniel - 03.06.2020, 18:02
RE: TELEGRAM APP - by JRP - 03.06.2020, 18:27
RE: TELEGRAM APP - by Daniel - 03.06.2020, 18:40
RE: TELEGRAM APP - by JRP - 03.06.2020, 18:57
RE: TELEGRAM APP - by Erwin van der Zwart - 03.06.2020, 21:06
RE: TELEGRAM APP - by olegrz - 06.01.2024, 17:51
RE: TELEGRAM APP - by olegrz - 07.01.2024, 09:09
RE: TELEGRAM APP - by admin - 04.06.2020, 04:36
RE: TELEGRAM APP - by baggins - 04.06.2020, 10:54
RE: TELEGRAM APP - by JRP - 04.06.2020, 07:35
RE: TELEGRAM APP - by admin - 04.06.2020, 11:17
RE: TELEGRAM APP - by phongvucba - 04.08.2020, 09:03
RE: TELEGRAM APP - by Daniel - 04.08.2020, 09:06
RE: TELEGRAM APP - by admin - 04.03.2021, 10:38
RE: TELEGRAM APP - by khalil - 04.03.2021, 10:44
RE: TELEGRAM APP - by khalil - 04.03.2021, 14:18
RE: TELEGRAM APP - by admin - 04.03.2021, 17:17
RE: TELEGRAM APP - by khalil - 08.03.2021, 14:28
RE: TELEGRAM APP - by admin - 09.03.2021, 07:08
RE: TELEGRAM APP - by khalil - 09.03.2021, 08:42
RE: TELEGRAM APP - by admin - 09.03.2021, 08:45
RE: TELEGRAM APP - by khalil - 09.03.2021, 09:24
RE: TELEGRAM APP - by edgars - 09.02.2022, 11:49
RE: TELEGRAM APP - by admin - 05.09.2022, 06:17
RE: TELEGRAM APP - by olegrz - 05.09.2022, 09:04
RE: TELEGRAM APP - by Daniel - 02.02.2023, 18:08
RE: TELEGRAM APP - by David - 26.04.2023, 07:28
RE: TELEGRAM APP - by admin - 26.04.2023, 07:28
RE: TELEGRAM APP - by David - 26.04.2023, 07:33
