Home Connect
(09.03.2021, 06:54)admin Wrote: After getting the device code you should send periodical requests to https://api.home-connect.com/security/oauth/token until you get a "200 OK" response. This will get you an access_token and a refresh_token. Put both into storage and use the access_token for all normal API calls. Since this token expires in one day you will need a scheduled script that will exchange the refresh_token for a new
access_token/refresh_token.
What would be the best practice for getting the scrip mentioned above just to run once? Make an event script, and put the code in memory?
Sent fra min SM-G980F via Tapatalk
Home Connect - by tomnord - 24.11.2020, 21:00
RE: Home Connect - by Erwin van der Zwart - 25.11.2020, 22:15
Home Connect - by tomnord - 11.02.2021, 21:17
RE: Home Connect - by admin - 12.02.2021, 12:17
RE: Home Connect - by tomnord - 08.03.2021, 20:03
RE: Home Connect - by admin - 09.03.2021, 06:54
RE: Home Connect - by tomnord - 09.03.2021, 15:32
RE: Home Connect - by Daniel - 09.03.2021, 15:44
