24.03.2021, 10:03
(24.03.2021, 09:51)admin Wrote: Arduino usually has automatic reset when the serial port is open. Check if restarting the script helps. You should also enable watchdog in your Arduino so it will reset itself if it hangs somewhere in the program.
I suppose by 'script' you mean the script that reads the Arduino data? That is also a scheduled script, so it gets restarted every 5 minutes... It does not reset the Arduino.
As for the watchdog: I have no real knowledge about Arduino's so I will have to inquire with the third party who provided the Arduino...
