25.03.2021, 15:32
(25.03.2021, 15:20)Daniel. Wrote: This is how the value works, it adjusts its size based on value. You can use one object with written value to adjust positions, duplicate it as may time yo need and then later when all is set just map correct objects.
if the user accidentally deletes the text, he no longer has the possibility of inserting it and cannot select it anymore.
I probably didn't understand your explanation, should I use a parking object and choosing what I need to update make a copy of the parking object text on the final object?
