Hi and thank you for your reply.
As I told you I am not familiar with scripting codes and I will appreciate if you can help me more regarding this. What do you mean by this '' First of all don't run this script with 0 sleep time''?
Also regarding : ''To write data to objects use grp.checkwrite(address, value). Make sure that you have created objects beforehand and that they have matching datatypes for the data that will be stored there (string, boolean, number).'' You mean that I have to create the functions with group addresses first in LM and after created them I have to insert that code continuing the firts code you send me or create another Script in Resident Script Tab?
I have to make many different scripts for each control at the same resident script for Yamaha or I have to create a new one?
I am sorry for asking but I am very new and I will need your help if possible
Also I found this API for Yamaha Musiccast Speaker in that link I am sending you. Can I use it to do something with this API and in which way? Maybe its easier to do it that way and just create buttons in visualization LM system ?
https://github.com/honnel/yamaha-commands
YamahaExtendedControl Protocol
Yamaha HTTP simplified API for Control Systems V1.1 - June 20, 2017
Overview
Yamaha provide a comprehensive API for control and interrogation of MusicCast devices. This document covers the most useful features, with examples, for integration in to CI Environments.
Prerequisites/Recommendations
For the HTTP API to function correctly in an integrated system, the MusicCast devices must be on a fixed or bound IP Address. To avoid network loops through the wireless “extend” functionality of MusicCast products you should set the device to wired or wireless only - through the web GUI on the MusicCast device:
HTTP API Overview
All HTTP transactions take place through a connection to the MusicCast device on port 80 (the default used by a web browser), and take the following form: HTTP:// [ipaddress] /YamahaExtendedControl/v1/... Example: http://[ipaddress]/YamahaExtendedControl/v1/system/getFeatures (recalls the available features on the MusicCast device)
HTTP API - Get information
Note that when a zone is specified below, the available zones per device can be recalled using the getLocationInfo command. In all examples main has been used. Get Device info http://[ipaddress]/YamahaExtendedControl/v1/system/getDeviceInfo Get Available Device Features http://[ipaddress]/YamahaExtendedControl/v1/system/getFeatures Get Network Status http://[ipaddress]/YamahaExtendedControl/v1/system/getNetworkStatus Get Function Status (e.g.: Auto Power Standby) http://[ipaddress]/YamahaExtendedControl/v1/system/getFuncStatus Get Location info and zone list (device) http://[ipaddress]/YamahaExtendedControl/v1/system/getLocationInfo Get zone info (device|zone) http://[ipaddress]/YamahaExtendedControl/v1/main/getStatus Get Sound Program List (device|zone) http://[ipaddress]/YamahaExtendedControl/v1/main/getSoundProgramList
HTTP API - Power Functions
Enable/Disable Auto Power http://[ipaddress]/YamahaExtendedControl/v1/system/setAutoPowerStandby?enable=true Standby http://[ipaddress]/YamahaExtendedControl/v1/system/setAutoPowerStandby?enable=false Power on http://[ipaddress]/YamahaExtendedControl/v1/main/setPower?power=on Standby http://[ipaddress]/YamahaExtendedControl/v1/main/setPower?power=standby Power Toggle http://[ipaddress]/YamahaExtendedControl/v1/main/setPower?power=toggle
HTTP API - Sleep Timer
Set in minutes. Use zone name from getLocationInfo Set Sleep timer for 60 minutes http://[ipaddress]/YamahaExtendedControl/v1/main/setSleep?sleep=60 Cancel Sleep timer http://[ipaddress]/YamahaExtendedControl/v1/main/setSleep?sleep=0
HTTP API - Input and Volume
Input: Net Radio http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=net_radio Input: Napster http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=napster Input: Spotify http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=spotify Input: Juke http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=juke Input: Qobuz http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=qobuz Input: Tidal http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=tidal Input: Deezer http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=deezer Input: Server http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=server Input: Bluetooth http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=bluetooth Input: Airplay http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=airplay Input: MusicCast link http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=mc_link The functions in the table above use autoplay to start the last item playing if the source is not already playing. Alternatively the autoplay_disabled function can be used: http://[ipaddress]/YamahaExtendedControl/v1/main/setInput?input=airplay&mode=autoplay_disabled Prepare Input Change (not necessary for direct input changes) Let a Device do necessary process before changing input in a specific zone. This is valid onlywhen “prepare_input_change” exists in “func_list” found in /system/getFuncStatus. http://[ipaddress]/YamahaExtendedControl/v1/main/prepareInputChange?input=usb Set Sound Program (where applicable) http://[ipaddress]/YamahaExtendedControl/v1/main//setSoundProgram?program=vienna
Volume Commands
For the Direct Volume function, the maximum volume setting available can be obtained from /system/getFeatures. For the stepped volume function thestep ranges are shown in the volume section of /system/getFeatures.
Direct Volume http://[ipaddress]/YamahaExtendedControl/v1/main/setVolume?volume=60 Incremental http://[ipaddress]/YamahaExtendedControl/v1/main/setVolume?volume=up http://[ipaddress]/YamahaExtendedControl/v1/main/setVolume?volume=down In Steps http://[ipaddress]/YamahaExtendedControl/v1/main/setVolume?volume=up&step=5 http://[ipaddress]/YamahaExtendedControl/v1/main/setVolume?volume=down&step=1
Mute Commands
Set Mute On http://[ipaddress]/YamahaExtendedControl/v1/main/setMute?enable=true Set Mute Off http://[ipaddress]/YamahaExtendedControl/v1/main/setMute?enable=false
HTTP API - AM/FM/DAB Tuner Commands
Tuner Presets Where band can be am, fm or dab Recall Preset http://[ipaddress]/YamahaExtendedControl/v1/tuner/recallPreset?zone=main&band=fm&num=13 Next Preset http://[ipaddress]/YamahaExtendedControl/v1/tuner/switchPreset?dir=next Previous Preset http://[ipaddress]/YamahaExtendedControl/v1/tuner/switchPreset?dir=previous Store Preset http://[ipaddress]/YamahaExtendedControl/v1/tuner/storePreset?num=10 Get Preset info http://[ipaddress]/YamahaExtendedControl/v1/tuner/getPresetInfo?band=fm Tuner - Get Playing info http://[ipaddress]/YamahaExtendedControl/v1/tuner/getPlayInfo Tuner - Set Frequency Where num represents frequency in KHz http://[ipaddress]/YamahaExtendedControl/v1/tuner/setFreq?band=fm&tuning=direct&num=87500
Tuner - Change DAB Service
Next Service http://[ipaddress]/YamahaExtendedControl/v1/tuner/setDabService?dir=next Previous Service http://[ipaddress]/YamahaExtendedControl/v1/tuner/setDabService?dir=previous http://[ipaddress]/YamahaExtendedControl/v1/tuner/setFreq?band=fm&tuning=direct&num=87500
HTTP API - Network/USB Presets and info
Recalls presets for any network or USB-based service. Playing info includes all metadata and image link Get Preset info http://[ipaddress]/YamahaExtendedControl/v1/netusb/getPresetInfo Get Current Playing info http://[ipaddress]/YamahaExtendedControl/v1/netusb/getPlayInfo Get Account Status (streaming services) http://[ipaddress]/YamahaExtendedControl/v1/netusb/getAccountStatus
HTTP API - System Presets
Recalls presets for the MusicCast system. Use zone name from getLocationInfo . Recall Preset http://[ipaddress]/YamahaExtendedControl/v1/netusb/recallPreset?zone=main&num=2 Store Preset http://[ipaddress]/YamahaExtendedControl/v1/netusb/storePreset?num=10
HTTP API - Transport Control
Sets Playback or transport mode. Stop http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=stop Play http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=play Previous http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=previous Next http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=next Fast Rewind - Start http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=fast_reverse_start Fast Rewind - Stop http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=fast_reverse_end Fast Forward - Start http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=fast_forward_start Fast Forward - Stop http://[ipaddress]/YamahaExtendedControl/v1/netusb/setPlayback?playback=fast_forward_end Repeat (Toggle) http://[ipaddress]/YamahaExtendedControl/v1/netusb/toggleRepeat Shuffle (Toggle) http://[ipaddress]/YamahaExtendedControl/v1/netusb/toggleShuffle
HTTP API - List info
Retrieve metadata and list entries. input is Input ID from /system/getFeatures | index is list offset from beginning | size is maximum list size 1-8) http://[ipaddress]/YamahaExtendedControl/v1/netusb/getListInfo?input=usb&index=32&size=8&lang=en
Overview
HTTP API Overview
Volume Commands
Mute Commands
