Openweather api
#28
I have modified the code so it works shown in the alert log the text Failed to load the Openweather weather information, if you put the return.
-- Comprobación de errores if type(Tabla_tiempo) == 'table' then        -- Si el contenido de la variable es distinto a una tabla entonces   alert('Fallo al cargar la información del tiempo de Openweather')         -- Si la llamada devuelve el codigo de error 401, 404 0 429 elseif Tabla_tiempo.cod == 401 then        alert('Fallo con la llave de la API de Openweather')        -- Mensajes de error   elseif Tabla_tiempo.cod == 404 then   alert('Fallo en la solicitud de la API de Openweather')   elseif Tabla_tiempo.cod == 429 then   alert('Fallo por exceder el límite de llamadas a la API de Openweather')   return end
The issue is that the error does not appear after successfully executing the script several times. I think only the first time.
Openweather api - by JRP - 20.07.2020, 11:13
RE: Openweather api - by admin - 20.07.2020, 11:16
RE: Openweather api - by JRP - 20.07.2020, 11:49
RE: Openweather api - by admin - 20.07.2020, 11:53
RE: Openweather api - by JRP - 20.07.2020, 15:43
RE: Openweather api - by JRP - 01.09.2020, 16:32
RE: Openweather api - by admin - 01.09.2020, 16:50
RE: Openweather api - by JRP - 02.09.2020, 11:01
RE: Openweather api - by admin - 02.09.2020, 11:09
RE: Openweather api - by victor.back - 14.11.2020, 20:37
RE: Openweather api - by JRP - 02.09.2020, 11:20
RE: Openweather api - by admin - 02.09.2020, 11:22
RE: Openweather api - by JRP - 02.09.2020, 11:41
RE: Openweather api - by Daniel - 02.09.2020, 11:43
RE: Openweather api - by JRP - 02.09.2020, 12:12
RE: Openweather api - by admin - 15.11.2020, 09:05
RE: Openweather api - by victor.back - 15.11.2020, 20:10
RE: Openweather api - by admin - 16.11.2020, 07:40
RE: Openweather api - by victor.back - 01.01.2021, 21:07
RE: Openweather api - by JRP - 19.04.2021, 10:20
RE: Openweather api - by admin - 19.04.2021, 10:23
RE: Openweather api - by JRP - 19.04.2021, 10:31
RE: Openweather api - by admin - 19.04.2021, 10:33
RE: Openweather api - by JRP - 19.04.2021, 10:38
RE: Openweather api - by admin - 19.04.2021, 10:41
RE: Openweather api - by JRP - 19.04.2021, 10:47
RE: Openweather api - by admin - 19.04.2021, 10:53
RE: Openweather api - by JRP - 19.04.2021, 11:04
RE: Openweather api - by davidchispas - 21.07.2021, 10:34
RE: Openweather api - by Daniel - 21.07.2021, 10:51
RE: Openweather api - by JRP - 30.08.2022, 10:28
RE: Openweather api - by admin - 30.08.2022, 10:29
RE: Openweather api - by JRP - 08.09.2022, 09:47
