Fronius inverter JSON integration
Since the addressing starts from 1 you need to subtract 1 from each address. You also need to read from input registers (read-only), not normal registers. Then there's a separate register which stores the scaling factor. Newer firmwares have an option to do a read test not only for RTU but also for TCP. It's more convenient than creating profiles for testing.
Try this profile:
{   "manufacturer": "Fronius",   "description": "Fronius Smartmeter TS 65A-3",   "mapping": [     {       "address": 2,       "address_scale": 6,       "bus_datatype": "float32",       "datatype": "int16",       "name": "AC Total Current value",       "type": "inputregister",       "units": "A",       "value_nan":[ 0x8000 ]     },     {       "address": 6,       "bus_datatype": "int16",       "datatype": "int16",       "internal": true,       "name": "A_SF",       "type": "inputregister",       "value_nan":[ 0x8000 ]     }   ] }
RE: Fronius inverter JSON integration - by admin - 23.04.2021, 06:46
