BIM ioT
(11.05.2021, 07:08)admin Wrote: 1. Install 2021 RC1 firmware.
2. Create a user library named websocket using the attached source.
3. Upload certificates via FTP using ftp login, rename files with long names to cert.pem and key.pem accordingly.
4. Create a resident script with 0 sleep time.
if not client then   require('json')   ws = require('websocket')   url = 'wss://test-hub.usbim.com'   client, err = ws.client('sync', 1)   opts = {     protocol = 'tlsv13',     key = '/home/ftp/key.pem',     password = [[*q&'wrKQsx+#bj8pbEV=%7Gpr"S+sxV2ngr`N}SjCC`X#rtt!wY6PL`d2'3!^x}u]],     certificate = '/home/ftp/cert.pem',     cafile = '/home/ftp/ca-chain.cert.pem',   }   res, err = client:connect(url, opts)   if not res then     log('connection failed', err)     client:sock_close()     client = nil   end end if client then   frame, opcode, clean, code, reason = client:receive()   log(frame, opcode, clean, code, reason)   if frame then     data = json.pcdecode(frame)     log(data)   elseif reason ~= 'timeout' then     log('connection dropped', reason)     client:sock_close()     client = nil   end end
This example is only a starting point, it should be extended with additional send/receive logic.
Thank you very much.... now I am getting that log.... I guess something is still wrong...
BIM ioT - by gdimaria - 06.05.2021, 15:05
RE: BIM ioT - by admin - 06.05.2021, 15:08
RE: BIM ioT - by gdimaria - 07.05.2021, 07:54
RE: BIM ioT - by gdimaria - 06.05.2021, 15:11
RE: BIM ioT - by admin - 07.05.2021, 07:59
RE: BIM ioT - by gdimaria - 10.05.2021, 16:16
RE: BIM ioT - by admin - 11.05.2021, 07:08
RE: BIM ioT - by gdimaria - 11.05.2021, 09:30
RE: BIM ioT - by admin - 11.05.2021, 09:32
RE: BIM ioT - by gdimaria - 11.05.2021, 09:41
RE: BIM ioT - by admin - 11.05.2021, 09:42
RE: BIM ioT - by gdimaria - 11.05.2021, 10:24
RE: BIM ioT - by admin - 13.05.2021, 06:23
RE: BIM ioT - by gdimaria - 13.05.2021, 09:05
RE: BIM ioT - by admin - 13.05.2021, 09:06
RE: BIM ioT - by gdimaria - 13.05.2021, 09:51
RE: BIM ioT - by admin - 13.05.2021, 09:53
RE: BIM ioT - by gdimaria - 13.05.2021, 10:01
RE: BIM ioT - by gdimaria - 28.05.2021, 11:07
RE: BIM ioT - by admin - 28.05.2021, 13:57
RE: BIM ioT - by gdimaria - 06.06.2021, 16:35
RE: BIM ioT - by admin - 07.06.2021, 09:59
RE: BIM ioT - by gdimaria - 09.06.2021, 15:17
RE: BIM ioT - by admin - 10.06.2021, 06:05
RE: BIM ioT - by gdimaria - 10.06.2021, 07:48
RE: BIM ioT - by admin - 10.06.2021, 07:53
RE: BIM ioT - by gdimaria - 10.06.2021, 08:26
RE: BIM ioT - by gdimaria - 10.06.2021, 09:27
RE: BIM ioT - by admin - 10.06.2021, 10:03
RE: BIM ioT - by gdimaria - 10.06.2021, 17:34
