Turning off scroll bouncing
Couple of things to try:
1. Add to Vis. graphics > Edit custom CSS:
html, body { overscroll-behavior: none; }
2. Add to Scripting > Tools > Custom JavaScript:
/*! iNoBounce - v0.2.0 * https://github.com/lazd/iNoBounce/ * Copyright (c) 2013 Larry Davis <lazdnet@gmail.com>; Licensed BSD */ (function(global) {     // Stores the Y position where the touch started     var startY = 0;     // Store enabled status     var enabled = false;     var supportsPassiveOption = false;     try {         var opts = Object.defineProperty({}, 'passive', {             get: function() {                 supportsPassiveOption = true;             }         });         window.addEventListener('test', null, opts);     } catch (e) {}     var handleTouchmove = function(evt) {         // Get the element that was scrolled upon         var el = evt.target;         // Allow zooming         var zoom = window.innerWidth / window.document.documentElement.clientWidth;         if (evt.touches.length > 1 || zoom !== 1) {             return;         }         // Check all parent elements for scrollability         while (el !== document.body && el !== document) {             // Get some style properties             var style = window.getComputedStyle(el);             if (!style) {                 // If we've encountered an element we can't compute the style for, get out                 break;             }             // Ignore range input element             if (el.nodeName === 'INPUT' && el.getAttribute('type') === 'range') {                 return;             }             var scrolling = style.getPropertyValue('-webkit-overflow-scrolling');             var overflowY = style.getPropertyValue('overflow-y');             var height = parseInt(style.getPropertyValue('height'), 10);             // Determine if the element should scroll             var isScrollable = scrolling === 'touch' && (overflowY === 'auto' || overflowY === 'scroll');             var canScroll = el.scrollHeight > el.offsetHeight;             if (isScrollable && canScroll) {                 // Get the current Y position of the touch                 var curY = evt.touches ? evt.touches[0].screenY : evt.screenY;                 // Determine if the user is trying to scroll past the top or bottom                 // In this case, the window will bounce, so we have to prevent scrolling completely                 var isAtTop = (startY <= curY && el.scrollTop === 0);                 var isAtBottom = (startY >= curY && el.scrollHeight - el.scrollTop === height);                 // Stop a bounce bug when at the bottom or top of the scrollable element                 if (isAtTop || isAtBottom) {                     evt.preventDefault();                 }                 // No need to continue up the DOM, we've done our job                 return;             }             // Test the next parent             el = el.parentNode;         }         // Stop the bouncing -- no parents are scrollable         evt.preventDefault();     };     var handleTouchstart = function(evt) {         // Store the first Y position of the touch         startY = evt.touches ? evt.touches[0].screenY : evt.screenY;     };     var enable = function() {         // Listen to a couple key touch events         window.addEventListener('touchstart', handleTouchstart, supportsPassiveOption ? { passive : false } : false);         window.addEventListener('touchmove', handleTouchmove, supportsPassiveOption ? { passive : false } : false);         enabled = true;     };     var disable = function() {         // Stop listening         window.removeEventListener('touchstart', handleTouchstart, false);         window.removeEventListener('touchmove', handleTouchmove, false);         enabled = false;     };     var isEnabled = function() {         return enabled;     };     // Enable by default if the browser supports -webkit-overflow-scrolling     // Test this by setting the property with JavaScript on an element that exists in the DOM     // Then, see if the property is reflected in the computed style     var testDiv = document.createElement('div');     document.documentElement.appendChild(testDiv);     testDiv.style.WebkitOverflowScrolling = 'touch';     var scrollSupport = 'getComputedStyle' in window && window.getComputedStyle(testDiv)['-webkit-overflow-scrolling'] === 'touch';     document.documentElement.removeChild(testDiv);     if (scrollSupport) {         enable();     }     // A module to support enabling/disabling iNoBounce     var iNoBounce = {         enable: enable,         disable: disable,         isEnabled: isEnabled     };     if (typeof module !== 'undefined' && module.exports) {         // Node.js Support         module.exports = iNoBounce;     }     if (typeof global.define === 'function') {         // AMD Support         (function(define) {             define('iNoBounce', [], function() { return iNoBounce; });         }(global.define));     }     else {         // Browser support         global.iNoBounce = iNoBounce;     } }(this));
Turning off scroll bouncing - by Zandkever - 13.05.2021, 08:09
RE: Turning off scroll bouncing - by Daniel - 13.05.2021, 08:14
RE: Turning off scroll bouncing - by admin - 13.05.2021, 08:50
RE: Turning off scroll bouncing - by admin - 13.05.2021, 14:21
RE: Turning off scroll bouncing - by admin - 14.05.2021, 07:42
