Check the amount of mobile account!
It should be something like this inside the SMS handler:
-- incoming sms handler handler = function(sms)  alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))   --******************************************  -- PUT HERE YOUR MATCH TO GET SMS PREPAID VALUE FROM SMS MESSAGE  local amount = sms.data:match([[va (.-) SMS]])  if amount ~= nil then    amount = tonumber(amount)    -- do something with amount  end  -- END MATCH TO GET SMS PREPAID VALUE FROM SMS MESSAGE  --******************************************  -- sms from known number, call parser  if table.contains(numbers, sms.sender) then    parser(sms.data, sms.sender)  end end
Now i fetch the value from the part of text ''va 550 SMS', now the match function grabs the 550 value out of the string, after that i make it a number instead of a string and you can do whatever you want with it.
Erwin van der Zwart
RE: Check the amount of mobile account! - by Erwin van der Zwart - 13.10.2016, 20:06
