Calculate value to procent
Looks like the above function you posted is javascript... are you running this in the custom javascript scripting part of lm?
if not and assuming you want lua try the below.
function rangePercentage (input, range_min, range_max, range_2ndMax)    percentage = ((input - range_min) * 100) / (range_max - range_min)   if percentage > 100 then     if  range_2ndMax then      percentage = ((range_2ndMax - input) * 100) / (range_2ndMax - range_max)       if percentage < 0 then           percentage = 0          else           percentage = 100       end           end         else if percentage < 0 then         percentage = 0       end   end       return percentage       end log(rangePercentage (65, 46, 195, 195))
Calculate value to procent - by Tokatubs - 10.06.2021, 18:55
RE: Calculate value to procent - by benanderson_475 - 11.06.2021, 02:51
RE: Calculate value to procent - by Tokatubs - 11.06.2021, 08:05
RE: Calculate value to procent - by admin - 11.06.2021, 08:11
RE: Calculate value to procent - by Tokatubs - 11.06.2021, 08:27
RE: Calculate value to procent - by tomnord - 07.05.2022, 14:29
RE: Calculate value to procent - by admin - 02.05.2022, 13:08
