Set export option with script
You can set the export field via a DB query:
db:update('objects', { export = 1 }, { id = 1 }) db:update('objects', { export = 1 }, { id = 2 }) db:update('objects', { export = 0 }, { id = 3 }) db:update('objects', { export = 1 }, { id = 4 }) script.reloadbacnet()
Check if you have the latest firmware because there was a bug when the BACnet service stopped working after a certain number of reload calls.
RE: Set export option with script - by admin - 21.06.2021, 06:42
RE: Set export option with script - by admin - 31.05.2023, 06:44
RE: Set export option with script - by admin - 31.05.2023, 11:45
