16.10.2016, 19:46
(This post was last modified: 16.10.2016, 20:25 by Erwin van der Zwart.)
Dail a number can be done by the command ATD*101#
Currently the script is build for SMS and the script uses now the command
AT+CMGS
You need to change the script by using the ATD command.
If you lookup documentation for AT commands for GSM modem you
can get all needed info.
I see no usecase for this and are not going to build this myself, so i won't spend
my time on re-writing the sms handler to a dailer.
See: https://www.sparkfun.com/datasheets/Cell...ide_r0.pdf
With this info you have the direction to go for (:
Good luck!
AT+CMGS
Good luck!
