Custom JavaScript examples
(11.10.2019, 19:46)Erwin van der Zwart Wrote: Hi,
Sorry, i tested with only 1 widget and then it works, but when having more then 1 widget i does not work (:
Here is a updated version for multiple widgets:
$(function(){    setInterval(function() {     var WidgetVisible = false;     $('.layer-widget').each(function( index, element ) {       if ( $(this).is(':visible') == true) {         WidgetVisible = true;       }     });     if (WidgetVisible == true){            $(".plan").css("opacity", 0.4);       $(".plan").css("transition", "opacity 1s ease-in-out");       $(".plan").css("-moz-transition", "opacity 1s ease-in-out");       $(".plan").css("webkit-transition", "opacity 1s ease-in-out");       $(".plan-background").css("opacity", 0.4);       $(".plan-background").css("transition", "opacity 1s ease-in-out");       $(".plan-background").css("-moz-transition", "opacity 1s ease-in-out");       $(".plan-background").css("webkit-transition", "opacity 1s ease-in-out");       $(".layout").css("opacity", 0.4);       $(".layout").css("transition", "opacity 1s ease-in-out");       $(".layout").css("-moz-transition", "opacity 1s ease-in-out");       $(".layout").css("webkit-transition", "opacity 1s ease-in-out");     } else {       $(".plan").css("opacity", 1);       $(".plan-background").css("opacity", 1);       $(".layout").css("opacity", 1);     }   }, 500);      });
The 500 refers to the interval, every 0.5 seconds the browser non stop checks for any open widgets.
thanks for this good JS
how to make the background read-only, means if I click outside the widget -where there are lights, shutters,....- the widget will close and nothing will be changed in the background
Please see the attached Built-in 251.600 6 byte DALI RGBW object widget
any idea @ admin
Best Regards,
Custom JavaScript examples - by edgars - 13.04.2016, 11:27
RE: Custom JavaScript examples - by edgars - 15.04.2016, 10:06
RE: Custom JavaScript examples - by buuuudzik - 16.04.2016, 18:53
RE: Custom JavaScript examples - by Joep - 21.03.2024, 09:26
RE: Custom JavaScript examples - by buuuudzik - 21.04.2016, 17:39
RE: Custom JavaScript examples - by buuuudzik - 25.04.2016, 08:53
RE: Custom JavaScript examples - by buuuudzik - 25.04.2016, 13:11
RE: Custom JavaScript examples - by Pawel - 26.04.2016, 19:23
RE: Custom JavaScript examples - by Pawel - 27.04.2016, 07:03
RE: Custom JavaScript examples - by Pawel - 27.04.2016, 08:05
RE: Custom JavaScript examples - by edgars - 28.04.2016, 08:30
RE: Custom JavaScript examples - by buuuudzik - 07.06.2016, 13:15
RE: Custom JavaScript examples - by buuuudzik - 08.06.2016, 06:47
RE: Custom JavaScript examples - by buuuudzik - 10.06.2016, 12:55
RE: Custom JavaScript examples - by buuuudzik - 13.06.2016, 06:27
RE: Custom JavaScript examples - by buuuudzik - 01.09.2016, 08:20
RE: Custom JavaScript examples - by Pawel - 13.06.2016, 06:59
RE: Custom JavaScript examples - by buuuudzik - 07.10.2016, 13:58
RE: Custom JavaScript examples - by admin - 13.06.2016, 09:02
RE: Custom JavaScript examples - by buuuudzik - 13.06.2016, 09:36
RE: Custom JavaScript examples - by buuuudzik - 13.06.2016, 12:21
RE: Custom JavaScript examples - by buuuudzik - 13.06.2016, 13:43
RE: Custom JavaScript examples - by buuuudzik - 13.06.2016, 16:52
RE: Custom JavaScript examples - by buuuudzik - 13.06.2016, 20:32
RE: Custom JavaScript examples - by gtsamis - 14.06.2016, 07:04
RE: Custom JavaScript examples - by admin - 14.06.2016, 07:31
RE: Custom JavaScript examples - by admin - 01.07.2016, 07:46
RE: Custom JavaScript examples - by admin - 01.07.2016, 10:18
RE: Custom JavaScript examples - by buuuudzik - 06.10.2016, 10:04
RE: Custom JavaScript examples - by admin - 07.10.2016, 17:38
RE: Custom JavaScript examples - by buuuudzik - 07.10.2016, 19:41
RE: Custom JavaScript examples - by buuuudzik - 10.10.2016, 13:17
RE: Custom JavaScript examples - by buuuudzik - 08.10.2016, 16:35
RE: Custom JavaScript examples - by buuuudzik - 08.10.2016, 19:01
RE: Custom JavaScript examples - by buuuudzik - 09.10.2016, 06:36
RE: Custom JavaScript examples - by buuuudzik - 09.10.2016, 15:32
RE: Custom JavaScript examples - by buuuudzik - 09.10.2016, 17:44
RE: Custom JavaScript examples - by admin - 10.10.2016, 09:24
RE: Custom JavaScript examples - by admin - 10.10.2016, 09:32
RE: Custom JavaScript examples - by admin - 10.10.2016, 13:34
RE: Custom JavaScript examples - by buuuudzik - 10.10.2016, 13:41
RE: Custom JavaScript examples - by buuuudzik - 11.10.2016, 09:59
RE: Custom JavaScript examples - by admin - 11.10.2016, 10:21
RE: Custom JavaScript examples - by admin - 11.10.2016, 10:46
RE: Custom JavaScript examples - by buuuudzik - 11.10.2016, 12:44
RE: Custom JavaScript examples - by admin - 11.10.2016, 12:51
RE: Custom JavaScript examples - by buuuudzik - 11.10.2016, 12:53
RE: Custom JavaScript examples - by admin - 11.10.2016, 12:54
RE: Custom JavaScript examples - by buuuudzik - 11.10.2016, 12:57
RE: Custom JavaScript examples - by admin - 11.10.2016, 13:04
RE: Custom JavaScript examples - by buuuudzik - 11.10.2016, 13:10
RE: Custom JavaScript examples - by buuuudzik - 13.10.2016, 12:57
RE: Custom JavaScript examples - by buuuudzik - 31.10.2016, 11:12
RE: Custom JavaScript examples - by cekca - 02.11.2016, 08:17
RE: Custom JavaScript examples - by admin - 02.11.2016, 11:23
RE: Custom JavaScript examples - by cekca - 02.11.2016, 14:28
RE: Custom JavaScript examples - by admin - 08.11.2016, 13:05
RE: Custom JavaScript examples - by buuuudzik - 05.12.2016, 19:11
RE: Custom JavaScript examples - by admin - 07.12.2016, 11:04
RE: Custom JavaScript examples - by Roman - 16.12.2016, 13:49
RE: Custom JavaScript examples - by admin - 16.12.2016, 14:58
RE: Custom JavaScript examples - by Roman - 16.12.2016, 15:38
RE: Custom JavaScript examples - by AEK - 22.01.2018, 07:01
RE: Custom JavaScript examples - by AEK - 22.01.2018, 08:48
RE: Custom JavaScript examples - by admin - 16.12.2016, 16:01
RE: Custom JavaScript examples - by FatMax - 24.12.2016, 00:08
RE: Custom JavaScript examples - by buuuudzik - 24.12.2016, 07:57
RE: Custom JavaScript examples - by Roman - 10.01.2017, 16:00
RE: Custom JavaScript examples - by AEK - 12.01.2017, 09:04
RE: Custom JavaScript examples - by buuuudzik - 16.01.2017, 16:30
RE: Custom JavaScript examples - by Pawel - 19.01.2017, 11:30
RE: Custom JavaScript examples - by buuuudzik - 19.01.2017, 16:25
RE: Custom JavaScript examples - by buuuudzik - 19.01.2017, 21:16
RE: Custom JavaScript examples - by buuuudzik - 19.01.2017, 21:58
RE: Custom JavaScript examples - by buuuudzik - 20.01.2017, 17:36
RE: Custom JavaScript examples - by admin - 21.01.2017, 07:35
RE: Custom JavaScript examples - by buuuudzik - 21.01.2017, 07:45
RE: Custom JavaScript examples - by buuuudzik - 25.01.2017, 06:10
RE: Custom JavaScript examples - by admin - 25.01.2017, 07:20
RE: Custom JavaScript examples - by rocfusion - 04.05.2017, 19:08
RE: Custom JavaScript examples - by admin - 18.05.2017, 05:54
RE: Custom JavaScript examples - by buuuudzik - 19.05.2017, 08:40
RE: Custom JavaScript examples - by admin - 19.05.2017, 09:05
RE: Custom JavaScript examples - by Gadjoken - 08.06.2017, 07:59
RE: Custom JavaScript examples - by David - 08.06.2017, 13:27
RE: Custom JavaScript examples - by admin - 08.06.2017, 17:21
RE: Custom JavaScript examples - by josep - 08.06.2017, 17:48
RE: Custom JavaScript examples - by baggins - 10.12.2017, 10:04
RE: Custom JavaScript examples - by Daniel - 11.12.2017, 10:28
RE: Custom JavaScript examples - by baggins - 11.12.2017, 11:06
RE: Custom JavaScript examples - by Daniel - 11.12.2017, 11:15
RE: Custom JavaScript examples - by baggins - 11.12.2017, 11:48
RE: Custom JavaScript examples - by admin - 11.12.2017, 11:52
RE: Custom JavaScript examples - by baggins - 11.12.2017, 12:25
RE: Custom JavaScript examples - by admin - 22.01.2018, 11:53
RE: Custom JavaScript examples - by gdimaria - 02.03.2018, 09:39
RE: Custom JavaScript examples - by gdimaria - 02.03.2018, 18:51
RE: Custom JavaScript examples - by gdimaria - 02.03.2018, 20:23
RE: Custom JavaScript examples - by mischa - 15.12.2020, 23:28
RE: Custom JavaScript examples - by buuuudzik - 04.03.2018, 21:14
RE: Custom JavaScript examples - by buuuudzik - 05.03.2018, 08:13
RE: Custom JavaScript examples - by buuuudzik - 06.03.2018, 07:17
RE: Custom JavaScript examples - by Mrinj - 24.03.2018, 20:29
RE: Custom JavaScript examples - by admin - 25.03.2018, 05:46
RE: Custom JavaScript examples - by Mrinj - 25.03.2018, 09:29
RE: Custom JavaScript examples - by Mrinj - 25.03.2018, 09:55
RE: Custom JavaScript examples - by DGrandes - 29.04.2019, 16:32
RE: Custom JavaScript examples - by admin - 29.04.2019, 17:00
RE: Custom JavaScript examples - by DGrandes - 30.04.2019, 10:28
RE: Custom JavaScript examples - by admin - 30.04.2019, 11:59
RE: Custom JavaScript examples - by DGrandes - 30.04.2019, 13:40
RE: Custom JavaScript examples - by admin - 30.04.2019, 14:04
RE: Custom JavaScript examples - by DGrandes - 30.04.2019, 15:38
RE: Custom JavaScript examples - by jlfneira - 08.08.2019, 08:45
RE: Custom JavaScript examples - by tecnorte - 01.04.2020, 11:09
RE: Custom JavaScript examples - by khalil - 05.07.2021, 08:08
RE: Custom JavaScript examples - by Daniel - 03.03.2020, 10:22
RE: Custom JavaScript examples - by Daniel - 03.03.2020, 10:56
RE: Custom JavaScript examples - by Hosutech - 06.03.2020, 07:47
RE: Custom JavaScript examples - by admin - 06.03.2020, 08:06
RE: Custom JavaScript examples - by gtsamis - 06.10.2020, 08:57
RE: Custom JavaScript examples - by admin - 06.10.2020, 09:18
RE: Custom JavaScript examples - by gtsamis - 06.10.2020, 09:41
RE: Custom JavaScript examples - by admin - 16.12.2020, 08:02
RE: Custom JavaScript examples - by mischa - 16.12.2020, 08:18
RE: Custom JavaScript examples - by admin - 16.12.2020, 08:25
RE: Custom JavaScript examples - by serkank - 26.04.2021, 09:37
RE: Custom JavaScript examples - by admin - 26.04.2021, 09:51
RE: Custom JavaScript examples - by serkank - 26.04.2021, 11:16
RE: Custom JavaScript examples - by tigi - 29.06.2021, 16:26
RE: Custom JavaScript examples - by admin - 29.06.2021, 16:46
RE: Custom JavaScript examples - by tigi - 07.07.2021, 09:09
RE: Custom JavaScript examples - by admin - 18.08.2023, 12:24
RE: Custom JavaScript examples - by admin - 18.08.2023, 13:02
RE: Custom JavaScript examples - by sgraystar - 07.04.2024, 21:29
RE: Custom JavaScript examples - by sgraystar - 08.04.2024, 07:08
RE: Custom JavaScript examples - by admin - 08.04.2024, 10:11
RE: Custom JavaScript examples - by Joep - 08.04.2024, 13:35
RE: Custom JavaScript examples - by admin - 08.04.2024, 13:36
RE: Custom JavaScript examples - by sgraystar - 09.04.2024, 00:07
RE: Custom JavaScript examples - by iridium - 23.07.2024, 17:07
RE: Custom JavaScript examples - by admin - 24.07.2024, 06:32
RE: Custom JavaScript examples - by iridium - 24.07.2024, 07:55
RE: Custom JavaScript examples - by admin - 22.08.2025, 12:48
RE: Custom JavaScript examples - by peyoe - 10.02.2026, 11:12
RE: Custom JavaScript examples - by admin - 10.02.2026, 11:26
RE: Custom JavaScript examples - by peyoe - 10.02.2026, 11:33
RE: Custom JavaScript examples - by admin - 10.02.2026, 11:34
RE: Custom JavaScript examples - by peyoe - 10.02.2026, 11:38
RE: Custom JavaScript examples - by peyoe - 11.02.2026, 12:31
RE: Custom JavaScript examples - by Daniel - 11.02.2026, 12:32
RE: Custom JavaScript examples - by peyoe - 11.02.2026, 12:50
RE: Custom JavaScript examples - by admin - 11.02.2026, 13:00
RE: Custom JavaScript examples - by Daniel - 11.02.2026, 13:01
RE: Custom JavaScript examples - by peyoe - 11.02.2026, 13:29
RE: Custom JavaScript examples - by admin - 11.02.2026, 13:33
RE: Custom JavaScript examples - by Daniel - 11.02.2026, 13:35
RE: Custom JavaScript examples - by peyoe - 11.02.2026, 13:50
RE: Custom JavaScript examples - by Daniel - 11.02.2026, 13:52
RE: Custom JavaScript examples - by peyoe - 11.02.2026, 13:59
