13.08.2021, 18:48
(13.08.2021, 09:21)admin Wrote: This can be optimized further by checking if the device as sent a telegram to a specific group address in the last X minutes. If it did then there's no point in checking the physical address. It's also advisable to add a small delay between each check so the bus is not overloaded.
For table iteration you can use ipairs, then the count loop is not needed (you can also use #addresses to get the table length).
Code:for _, address in ipairs(addresses) do result = knxlib.ping(address) if result == false then content2 = content2 .. 'Address: ' .. address .. ' - <b>ERROR!</b><br>' end end
See a similar example for the second function: https://forum.logicmachine.net/showthread.php?tid=1967
Thank you all for the support.
I have added all devices on the table and added a delay for the ping function. Mail also works well.
addresses = {
'1.1.1',
'1.1.2',
'1.1.3',
'1.1.4',
'1.1.5',
'1.1.6',
'1.1.7',
'1.1.8',
'1.1.9',
'1.1.10',
'1.1.11',
'1.1.12',
'1.1.13',
'1.1.14',
'1.1.15',
'1.1.16',
'1.1.17',
'1.1.18',
'1.1.19',
'1.1.20',
'1.1.21',
'1.1.22',
'1.1.23',
'1.1.24',
'1.1.25',
'1.1.26',
'1.1.27',
'1.1.28',
'1.1.29',
'1.1.30',
'1.1.31',
'1.1.32',
'1.1.33',
'1.1.34',
'1.1.35',
'1.1.36',
'1.1.37',
'1.1.38',
'1.1.39',
'1.1.40',
'1.1.41',
'1.1.42',
'1.1.43',
'1.1.44',
'1.2.1',
'1.2.2',
'1.2.3',
'1.2.4',
'1.2.5',
'1.2.6',
'1.2.7',
'1.2.8',
'1.2.9',
'1.2.10',
'1.2.11',
'1.2.13',
'1.2.14',
'1.2.15',
'1.2.16',
'1.2.17',
'1.2.18',
'1.2.19',
'1.2.20',
'1.2.21',
'1.2.22',
'1.2.23',
'1.2.24',
'1.2.25',
'1.2.26',
'1.2.27',
'1.2.28',
'1.2.29',
'1.2.30',
'1.2.31',
'1.2.32',
'1.2.33',
'1.2.34',
'1.2.35',
'1.2.36',
'1.2.37',
'1.2.38',
'1.2.39',
'1.2.40',
'1.2.41',
'1.2.42',
'1.2.43',
'1.2.44',
'1.2.45',
'1.2.46',
'1.2.47',
'1.2.48',
'1.2.49',
'1.2.50',
'1.2.51',
'1.2.52',
'1.2.53',
'1.2.54',
'1.2.55',
'1.2.56',
'1.3.1',
'1.3.2',
'1.3.3',
'1.3.4',
'1.3.5',
'1.3.6',
'1.3.7',
'1.3.8',
'1.3.9',
'1.3.10',
'1.3.11',
'1.3.12',
'1.3.13',
'1.3.14',
'1.3.15',
'1.3.16',
'1.3.17',
'1.3.18',
'1.3.19',
'1.3.20',
'1.3.21',
'1.3.22',
'1.3.23',
'1.3.24',
'1.3.25',
'1.3.26',
'1.3.27',
'1.3.28',
'1.3.29',
'1.3.30',
'1.3.31',
'1.3.32',
'1.3.33',
'1.3.34',
'1.3.35',
'1.3.36',
'1.3.37',
'1.3.38',
'1.3.39',
'1.3.40',
'1.3.41',
'1.3.42',
'1.3.43',
'1.3.44',
'1.3.45',
'1.3.46',
'1.3.47',
'1.3.48',
'1.3.49',
'1.3.50',
'1.3.51',
'1.3.52',
'1.3.53',
'1.3.54',
'1.3.55',
'1.3.56',
'1.3.57',
'1.3.58',
'1.4.1',
'1.4.2',
'1.4.3',
'1.4.4',
'1.4.5',
'1.4.6',
'1.4.7',
'1.4.8',
'1.4.9',
'1.4.10',
'1.4.11',
'1.4.12',
'1.4.13',
'1.4.14',
'1.4.15',
'1.4.16',
'1.4.17'
--Address Count
ie=1
while (addresses[ie]~=nil) do
ie=ie+1
--ping addresses
content='<b>KNX Physical Address Check</b><br><br>'
content2=''
os.sleep(0.5)
content2 = content2 .. 'Motion Detector - Address: ' .. address .. ' - <b>IS OFFLINE!</b><br>'
--send email
if content2 ~= '' then
res, err = mail('123456@gmail.com', 'KNX Installation Fault',content2)
endAfter the mail function I would like to reset the motion detection telegram of the device(s) that is offline. I was thinking to tag the group address with the phys address and then have a function in this scipt to write to the result a false.
How can i do this?
Or can I add an array of data to include the address and next to it the coresponding motion detection GA?
something like this
{ address = '1.1.1', motion = '2/1/1' },
{ address = '1.1.2', motion = '2/1/2' }
In this case how would the script look like?
