Lost object changes - workaround?
Hi Thomas,
Use this as framework, the rest is up to you (;
You have 4 object listeners now in this framework that respond on KNX values.
<!DOCTYPE html"> <head>  <title>homeLYnk by Schneider Electric</title>  <style type="text/css">    body {      background-color: transparent;    }  </style> </head> <body> <script type="text/javascript">  // ***** Make link to parent from iframe *****  var p = window.parent, root, addr;  if (p && p.objectStore){      // Add event listeners on KNX addresses    addr1 = p.Scada.encodeGroupAddress('1/1/1');        p.objectStore.addListener(addr1, function(obj, type) {      // to avoid (re)trigger on opening page */      if (type == 'init') {         return;        // Or do your JavaScript actions on received value on page load      } else {        // Do your JavaScript actions on new received value      }    });    addr2 = p.Scada.encodeGroupAddress('1/1/2');        p.objectStore.addListener(addr2, function(obj, type) {      // to avoid (re)trigger on opening page */      if (type == 'init') {         return;        // Or do your JavaScript actions on received value on page load      } else {        // Do your JavaScript actions on new received value      }    });    addr3 = p.Scada.encodeGroupAddress('1/1/3');        p.objectStore.addListener(addr3, function(obj, type) {      // to avoid (re)trigger on opening page */      if (type == 'init') {         return;        // Or do your JavaScript actions on received value on page load      } else {        // Do your JavaScript actions on new received value      }    });    addr4 = p.Scada.encodeGroupAddress('1/1/4');        p.objectStore.addListener(addr4, function(obj, type) {      // to avoid (re)trigger on opening page */      if (type == 'init') {         return;        // Or do your JavaScript actions on received value on page load      } else {        // Do your JavaScript actions on new received value      }    });     } </script> </body> </html>
If you look in custom javascript section you can find a newer version of the object listener (something like grp.listen), but this one i had copy-paste ready (;
Lost object changes - workaround? - by Thomas - 24.10.2016, 19:09
RE: Lost object changes - workaround? - by Erwin van der Zwart - 25.10.2016, 13:27
