Loop script
You can start and stop a script with command of this.
Answer to a question of me
(12.10.2021, 12:22)admin Wrote: Simply create an event script attached to a 1-bit boolean object and put this into the editor.
enable = event.getvalue() script.set('bedroom [fb], turn off', enable)
if im right, group adress '32/1/126' is the start and stop adres for this script?
you can add the script (of Admin) above in this group adres to start and stop this script,
I used the script like this
if lights_TM == true then script.set('01.03 0 study (tm) (vertraging uit)', enable) elseif lights_TM == false  then script.set('01.03 0 study (tm) (vertraging uit)', disable) end
and use your script you post here in a resident script.
Loop script - by victor.back - 16.10.2021, 14:02
RE: Loop script - by Dré - 17.10.2021, 10:04
RE: Loop script - by victor.back - 18.10.2021, 12:57
RE: Loop script - by admin - 18.10.2021, 06:06
