openweather ONE call API
Hi @all,
due to the great hints of you guys I got the first script running for the current temperature and humidity value.
Now I want to get also the current weather description and the daily forecast for temperature min and max.
Unfortunately this values are not working. In the script log I see the following message:
User script:39: attempt to index field 'temp' (a nil value) stack traceback:
Here is my actual script:
require('json') http = require('socket.http') appid = 'XXX' lat = 'XXX' lon ='XXX' lang = 'en' units = 'metric' url = 'http://api.openweathermap.org/data/2.5/onecall?lat=%s&lon=%s&units=%s&lang=%s&appid=%s' url = string.format(url, lat, lon, units, lang, appid) res, code, headers, status = http.request(url) log (code, status, headers) data = json.pdecode(res) --Fault messages: if not data then   alert('Error converting data')   return end if not res then   alert('Error collecting data')   return end current = data.current daily = data.daily -- current temperature grp.write('41/1/1', current.temp) -- current Weather condition grp.write('41/1/2', current.weather.description) --current Humidity grp.write('41/1/3', current.humidity) --daily forecast Temperature min grp.write('41/1/4', daily.temp.min) --daily forecast Temperature max grp.write('41/1/5', daily.temp.max)
Do you have an idea what might be wrong?
Many thanks for your help!
Best Regards
Steffen
openweather ONE call API - by pioneersteffen - 17.10.2021, 11:35
RE: openweather ONE call API - by admin - 18.10.2021, 06:07
RE: openweather ONE call API - by JRP - 19.10.2021, 10:16
RE: openweather ONE call API - by pioneersteffen - 20.10.2021, 19:23
RE: openweather ONE call API - by admin - 21.10.2021, 06:22
RE: openweather ONE call API - by admin - 22.10.2021, 06:43
RE: openweather ONE call API - by admin - 25.10.2021, 06:50
RE: openweather ONE call API - by AlexLV - 30.10.2021, 20:03
RE: openweather ONE call API - by AlexLV - 31.10.2021, 14:30
RE: openweather ONE call API - by admin - 15.01.2024, 09:14
RE: openweather ONE call API - by admin - 15.01.2024, 10:26
RE: openweather ONE call API - by admin - 15.01.2024, 10:32
