openweather ONE call API
I trying to integrate the alerts as well. Unfortuantely I getting the following error:
Openweathermap 22.10.2021 19:39:38 User script:52: attempt to index global 'alerts' (a nil value) stack traceback: User script:52: in main chunk
Do you have an idea what might be wrong?
Here is the complete code:
require('json') http = require('socket.http') appid = 'xxx' lat = 'xxx' lon ='xxx' lang = 'de' units = 'metric' url = 'http://api.openweathermap.org/data/2.5/onecall?lat=%s&lon=%s&units=%s&lang=%s&appid=%s' url = string.format(url, lat, lon, units, lang, appid) res, code, headers, status = http.request(url) log (code, status, headers) data = json.pdecode(res) --Fault messages: if not data then   alert('Error converting data')   return end if not res then   alert('Error collecting data')   return end current = data.current daily = data.daily[1] alerts = data.alerts -- current temperature grp.write('41/1/1', current.temp) --current Humidity grp.write('41/1/3', current.humidity) --current wind speed grp.write('41/1/6', current.wind_speed) --daily forecast Temperature min grp.write('41/1/4', daily.temp.min) --daily forecast Temperature max grp.write('41/1/5', daily.temp.max) -- daily Weather condition grp.write('41/1/2', daily.weather[1].description) --daily forecast wind gust grp.write('41/1/7', daily.wind_gust) --daily forecast max UV Index grp.write('41/1/8', daily.uvi) --daily forecast max UV Index grp.write('41/1/9', daily.rain) --alerts grp.write('41/1/10', alerts.event) wetterprognose = math.ceil(daily.temp.min).."/"..math.ceil(daily.temp.max).."/"..daily.rain.."/"..math.ceil(daily.wind_gust).."/"..math.ceil(daily.uvi) --sending daily weather forecast to MDT Taster grp.write('41/2/1', wetterprognose)
Many thanks for your help!
Best Regards
Steffen
openweather ONE call API - by pioneersteffen - 17.10.2021, 11:35
RE: openweather ONE call API - by admin - 18.10.2021, 06:07
RE: openweather ONE call API - by JRP - 19.10.2021, 10:16
RE: openweather ONE call API - by admin - 21.10.2021, 06:22
RE: openweather ONE call API - by admin - 22.10.2021, 06:43
RE: openweather ONE call API - by pioneersteffen - 22.10.2021, 17:43
RE: openweather ONE call API - by admin - 25.10.2021, 06:50
RE: openweather ONE call API - by AlexLV - 30.10.2021, 20:03
RE: openweather ONE call API - by AlexLV - 31.10.2021, 14:30
RE: openweather ONE call API - by admin - 15.01.2024, 09:14
RE: openweather ONE call API - by admin - 15.01.2024, 10:26
RE: openweather ONE call API - by admin - 15.01.2024, 10:32
