Number of "Pulses" Detection
Resident script with sleep time set to 0. You only need to edit the config table. You will need to restart the script via disable/enable after each config edit. In the config table each key is a group address which sends 1 on button press and 0 on button release. Value for each key is another table with the button configuration. This way you only need a single script for all buttons with multiple press functionality.
if not client then   config = {     ['0/0/1'] = {       timeout = 0.5,       longpress = 1,       press = function(ptype, count)         local light1 = '1/1/1'         local light2 = '1/1/2'         if ptype == 'short' then           if count == 1 then             grp.write(light1, not grp.getvalue(light1))           else             grp.write(light2, not grp.getvalue(light2))           end         else           grp.write(light1, false)           grp.write(light2, false)         end       end     },     ['1/1/3'] = {       timeout = 0.5,       press = function(ptype, count)         log('press 1/1/3', ptype, count)       end     }   }   function groupwrite(event)     local cfg = config[ event.dst ]     if cfg then       cfg.pressed = tonumber(event.datahex, 16) ~= 0       if cfg.pressed then         cfg.timer = 0         cfg.count = (cfg.count or 0) + 1       end     end   end   function press(cfg, ptype, count)     if type(cfg.press) == 'function' then       cfg.press(ptype, count)     end     cfg.pressed = false     cfg.timer = nil     cfg.count = 0   end   client = require('localbus').new(0.1)   client:sethandler('groupwrite', groupwrite) end ts, tu = os.microtime() client:loop(0.2) diff = math.max(0, os.udifftime(ts, tu)) for addr, cfg in pairs(config) do   if cfg.timer then     cfg.timer = cfg.timer + diff     if cfg.pressed then       if cfg.longpress and cfg.timer >= cfg.longpress then         press(cfg, 'long')       end     elseif cfg.timer >= (cfg.timeout or 1) then       press(cfg, 'short', cfg.count)     end   end end
Number of "Pulses" Detection - by p_xatzi - 04.10.2021, 11:06
RE: Number of "Pulses" Detection - by Daniel - 04.10.2021, 11:17
RE: Number of "Pulses" Detection - by p_xatzi - 04.10.2021, 14:15
RE: Number of "Pulses" Detection - by p_xatzi - 25.10.2021, 11:12
RE: Number of "Pulses" Detection - by admin - 25.10.2021, 11:35
RE: Number of "Pulses" Detection - by admin - 26.10.2021, 08:18
RE: Number of "Pulses" Detection - by p_xatzi - 26.10.2021, 09:31
RE: Number of "Pulses" Detection - by admin - 26.10.2021, 09:39
RE: Number of "Pulses" Detection - by p_xatzi - 31.10.2021, 22:15
RE: Number of "Pulses" Detection - by admin - 01.11.2021, 07:32
RE: Number of "Pulses" Detection - by p_xatzi - 20.04.2022, 07:22
RE: Number of "Pulses" Detection - by admin - 20.04.2022, 07:36
RE: Number of "Pulses" Detection - by p_xatzi - 20.04.2022, 08:23
