Log all packets from 15.15.*
Hi Klaus,
you could use such script and customize handleLog function according to your needs.
if not client then   require('genohm-scada.eibdgm')   objects = grp.all()   datatypes = {}   for _, object in ipairs(objects) do     datatypes[ object.id ] = object.datatype   end     function handleLog(src, eventType, ga, value, rawEvent)     local isLoggedAddress = src:find("15.15.%d+") ~= nil     if isLoggedAddress then       log(src, eventType, ga, value, os.time())     end   end   function writehandler(event)     local dpt, dst = datatypes[ event.dstraw ], event.dst     local value = nil         if dpt then       value = knxdatatype.decode(event.datahex, dpt)     end         handleLog(event.src, event.type, dst, value, event)   end       client = eibdgm:new({ timeout = 0.5 })   client:sethandler('groupwrite', writehandler) end -- handle knx client:step()
You could look also into these posts:
https://forum.logicmachine.net/showthrea...ght=eibdgm
Done is better than perfect
Log all packets from 15.15.* - by kgroenhoej - 10.11.2021, 17:40
RE: Log all packets from 15.15.* - by buuuudzik - 10.11.2021, 19:17
