30.10.2016, 17:26
I've really had a bad weekend and I am unable to program anymore my electric panel via LM4. I will describe below the syndromes that I am experiencing:
1. Before restarting, the LM4 had the lower led blinking intermittently in red/green. What this means? CPU high activity? Due to what?
2. When I read the addresses on the line, they are randomly read via LM4's remote connection. I've repeated the scan 3 times and found that the results are different and not all the devices are discovered. Do I have a timeout somewhere? Has anyone experiencing the same issue?
3. I am unable to program any of my KNX switches (and other KNX devices). Most of the devices are not responding anymore, although yesterday I was able to program them all by pressing the button in the back of the devices. This has happened at the first try.
I am connected via local LAN using a Gigabit Ethernet connection. My ETS3 is virtualised on an iMac via Parallels Desktop, with a Windows 7 running as virtual machine.
I cannot program anything right now and I am stuck without switches in my home (don't laugh!
) and I can control the lights just using the iPhone and the Schneider's 7" Touch Panel. I won't ever try to see what would happen if I re-program an dimming/switching actuator, as I will probably stay without lights in my flat...
Please advise. Should I rollback to another version? Or is it a known problem?
Andreas
) and I can control the lights just using the iPhone and the Schneider's 7" Touch Panel. I won't ever try to see what would happen if I re-program an dimming/switching actuator, as I will probably stay without lights in my flat...Please advise. Should I rollback to another version? Or is it a known problem?
Andreas
