21.12.2021, 15:55
Hi, Thanks for the idea. I did that and it works great. I made two Event scripts, one for the real lighting group 35, and another for the slave PIR group 73.
In the event script for 35, I first check the event sender to make sure it really came from the physical bus or the visualization, then I create/set a storage object and set it to true when the switch turns on, or false when off.
Normal bus/system functionality turns the actual light on/off.
In the other event script for the PIR group 73, I turn on the light when this event value is '1' but if it is '0', I have a nested "If" to additionally check if the storage pseudo-blocker object is true or false before attempting to control the light. Works Perfect, and no rework is required to any other part of the system.
Thanks again!
Thanks again!
