problem with 4g modem
(01.02.2022, 13:35)admin Wrote: You have the same code in the resident script twice, this can lead to errors. You've also commented out all alerts so there's no way of knowing if the script is working or not.
Replace your resident script with this and post what you get in alerts:
-- init if not numbers then   require('user.sms')   require('json')   require('socket')   -- allowed numbers, SMS from other numbers will be ignored   numbers = { '3332958126' }   -- port number depends on modem model   comport = 'ttyACM3'   doreset = false -- set to true if USB reset is required before starting any communication   -- if SIM PIN is enabled, uncomment the line below and replace 0000 with SIM PIN   -- pincode = '0000'   -- command parser   parser = function(cmd, sender)     local find, pos, name, mode, offset, value, dvalue, obj, message     cmd = cmd:trim()     mode = cmd:sub(1, 1):upper()     -- invalid request     if mode ~= 'W' and mode ~= 'R' then       return     end     cmd = cmd:sub(3):trim()     -- parse object name/address     find = cmd:sub(1, 1) == '"' and '"' or ' '     offset = find == '"' and 1 or 0     -- pad with space when in read mode     if mode == 'R' and find == ' ' then       cmd = cmd .. ' '     end     -- find object name     pos = cmd:find(find, 1 + offset, true)     -- name end not found, stop     if not pos then       return     end     -- get name part     name = cmd:sub(1 + offset, pos - offset):trim()     if mode == 'W' then       value = cmd:sub(pos + offset):trim()       if #value > 0 then         -- try decoding value         dvalue = json.pdecode(value)         if dvalue ~= nil then           value = dvalue         end         -- send to bus         grp.write(name, value)       end     -- read request     else       obj = grp.find(name)       -- object not known       if not obj then         return       end       -- send read request and wait for an update       obj:read()       os.sleep(1)       -- read new value       value = grp.getvalue(name)       -- got no value       if value == nil then         return       end       -- add object name if specified       if obj.name then         name = string.format('%s (%s)', obj.name, obj.address)       end       message = string.format('Value of %s is %s', name, json.encode(value))       modem:sendsms('+' .. sender, message)     end   end   -- incoming sms handler   handler = function(sms)     --alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))     -- sms from known number, call parser     if table.contains(numbers, sms.sender) then       --parser(sms.data, sms.sender)     end   end   -- check local udp server for messages to send   udphandler = function(server)     -- check for local sms to send     local msg = server:receive()     -- got no message     if not msg then       return     end     -- split into number and message     local sep = msg:find(' ')     if not sep then       return     end     alert('sending sms: ' .. msg)     modem:sendsms(msg:sub(1, sep - 1), msg:sub(sep + 1))   end end -- handle data from modem if modem then   if modem:run() then     udphandler(server)   else     alert('SMS handler lost connection')     modem:reinit()   end -- modem init else   alert('SMS handler init')   -- open serial port   modem = AT:init('/dev/' .. comport, doreset)   -- init ok   if modem then     -- set sms handler     modem:setsmshandler(handler)     -- send pin if set     if pincode then       modem:send('AT+CPIN=' .. pincode)       modem:read()     end     -- set to pdu mode     modem:send('AT+CMGF=0')     -- enable sms notifications     modem:send('AT+CNMI=1,1,0,0,0')     -- fixup encoding     modem:send('AT+CSCS="GSM"')     -- delete all saved messages     modem:send('AT+CMGD=1,4')     -- local udp server for sending sms     server = socket.udp()     server:setsockname('127.0.0.1', 12535)     server:settimeout(0.1)     alert('SMS handler started')   -- init failed   else     alert('SMS USB init failed')   end end
problem to init
problem with 4g modem - by Frank68 - 31.01.2022, 14:03
RE: problem with 4g modem - by admin - 31.01.2022, 15:30
RE: problem with 4g modem - by Frank68 - 31.01.2022, 16:05
RE: problem with 4g modem - by admin - 01.02.2022, 08:20
RE: problem with 4g modem - by Frank68 - 01.02.2022, 12:12
RE: problem with 4g modem - by admin - 01.02.2022, 12:18
RE: problem with 4g modem - by Frank68 - 01.02.2022, 12:24
RE: problem with 4g modem - by admin - 01.02.2022, 13:35
RE: problem with 4g modem - by Frank68 - 01.02.2022, 14:54
RE: problem with 4g modem - by admin - 01.02.2022, 14:56
RE: problem with 4g modem - by Frank68 - 01.02.2022, 15:08
RE: problem with 4g modem - by admin - 02.02.2022, 09:13
RE: problem with 4g modem - by Frank68 - 02.02.2022, 09:23
RE: problem with 4g modem - by admin - 02.02.2022, 09:24
RE: problem with 4g modem - by admin - 02.02.2022, 09:53
RE: problem with 4g modem - by Frank68 - 02.02.2022, 09:54
RE: problem with 4g modem - by Frank68 - 02.02.2022, 14:06
RE: problem with 4g modem - by admin - 03.02.2022, 07:27
RE: problem with 4g modem - by Frank68 - 03.02.2022, 07:32
RE: problem with 4g modem - by admin - 01.07.2024, 09:01
RE: problem with 4g modem - by admin - 01.07.2024, 09:34
RE: problem with 4g modem - by admin - 01.07.2024, 09:48
RE: problem with 4g modem - by admin - 01.07.2024, 10:22
RE: problem with 4g modem - by admin - 01.07.2024, 12:22
RE: problem with 4g modem - by admin - 01.07.2024, 14:08
RE: problem with 4g modem - by EjvindHald - 26.09.2025, 11:22
RE: problem with 4g modem - by admin - 26.09.2025, 12:34
RE: problem with 4g modem - by EjvindHald - 26.09.2025, 13:27
RE: problem with 4g modem - by admin - 26.09.2025, 13:34
RE: problem with 4g modem - by EjvindHald - 26.09.2025, 13:39
RE: problem with 4g modem - by admin - 26.09.2025, 13:40
RE: problem with 4g modem - by EjvindHald - 26.09.2025, 13:52
RE: problem with 4g modem - by admin - 26.09.2025, 14:11
RE: problem with 4g modem - by EjvindHald - 26.09.2025, 14:19
RE: problem with 4g modem - by EjvindHald - 29.09.2025, 06:43
RE: problem with 4g modem - by admin - 29.09.2025, 06:55
RE: problem with 4g modem - by EjvindHald - 29.09.2025, 16:51
RE: problem with 4g modem - by admin - 01.10.2025, 10:38
